edelbrock type r header & test pipe
Does anyone out there have an edelbrock header on their r? If so, how is it? Also, does anyone know if a test pipe off a '92 Integra RS will fit an R?
The header has a 1.75" collector so you can just bolt it on to the stock cat or test pipe. Edelbrock claims it makes power but I wanted to know if anyone had one on their ride. I guess the best thing to do is grab a JDM DC header and slice my cat up. 5-10 horse is worth it.
Guest
Posts: n/a
a JDM header has a 2.5" collector (Anything that bolts to your stock cat is 2.25", not 1.75").
You do not want to cut up your 2.25" stock cat to fit a JDM header. It woudl be easier and likely just as cheap to buy a carsound cat made to the length you need. You can get them as cheap as $120. I am not a DC sports fan due to it's ground clearance. I prefer the OEM JDM 4-1 and an upper heatshield.
Trey
Trey
