Changing Spark Plugs
Old 07-21-2003, 01:04 PM
40calpal
40calpal's Avatar
hey i need to change my sparkplugs and i've never tried it before, do u think it'd be easier to just let a mechanic mess with it or does anyone have an easy do-it-u'rself link?
Also any recommendations on brands? Or should i just head down to Auto-zone and pick some up? Thanks for any advice
Old 07-21-2003, 01:47 PM
40calpal
40calpal's Avatar
By spark plugs of course i mean fuel injectors :P
Old 07-21-2003, 01:52 PM
kabob
kabob's Avatar
Why the heck are you changing your fuel injectors? They're not designed to wear out or need changing and if you're doing some motor work, you should have a Helms manual in the first place that will give you diagrams along with a few step-by-steps for changing them. I wouldn't recommend touching them unless you've got one.
Old 07-21-2003, 03:30 PM
Jan Niemi
Jan Niemi's Avatar
WTF?
Old 07-21-2003, 10:28 PM
nw98typer
nw98typer's Avatar
And I don't think I'd replace injectors with anything at available at Autozone.
Old 07-22-2003, 08:31 AM
MastrHU
MastrHU's Avatar
nothing wrong with needing advice, but you should have a manual for your car. it will save you money. sparkplugs or injectors? it's very easy to replace either of them on your engine. do not pay a mechanic when it will only take less then 15 minutes to replace either the injectors or the plugs. don't know why you would have to replace injectors, but if you are replacing them to upgrade your fuel system, go with the late model prelude injectors. i believe they are 280cc and they drop right in and you can find them on the partstrader for cheap. also, get some seal grease so you don't damage the orings on the injectors when sliding them in.
