? on JDM engines
I nearly wet myself!
? on JDM engines
What are the differences between the H22a and the type S? Just out of curiousity.
edit: Beside the 20 HP difference.(before I get any "smart" remarks )
~Bob
~Bob
Like you said, beside the more sporty cam and 20 hp, the type-S also has 11:1 compression and the h22a has 10.6:1. The type-S also comes ported and polished from Honda. Those are the only differences I can think of.
How does anyone justify the hugh price differences between these just because of a different cam and port & polish? :wtf:
i can build a type-s out of an h22a, best of both worlds...closed deck and OBD1 for cheaper than a OBD2 type-s motor.
~boom
Originally Posted by ludeboom
dont forget the pistons
~boom
~boom
That would probably be the way to go then. Ok real newb question ludeboom. What is the difference between an open and closed deck?
it basically has sleeve like tubes for the cylinders, with direct coolant head contact via the block.
closed deck is 93-96 USDM h22a1 models, and 92-98 jdm h22a motors.
~boom
So what are the differences between the H22a1 and the H22a? JUST THE BLOCK! I am thinking I want to start with just a block and build it up piece by piece as I get the money. Any other suggestions would be cool to.
the h22a and h22a1 are the same block for the most part, both closed deck. the newer OBD2 motors are open deck.
you should buy a motor from an importer and tear it down, then build it to your specs/liking. ive done this several times, and its like second nature from me now, but if you want to be like me, start where i started...with the 1400 page helms manual for a 1994 USDM prelude.
worth every penny i paid for it ($92)
~boom
Rotorphile.
Same deal with the B18C and the B18C Type-R. The price difference isn't worth the gain, it's just rarer and in higher demand.
