90K Maintenance?
Old 02-29-2004, 05:51 AM
EliteBob13
I nearly wet myself!
EliteBob13's Avatar
Default 90K Maintenance?
Obviously I need to replace the timing belt. But what else am I looking at for the 90K maintenance? Money is kinda tight now since I decided to buy a home before I go hog wild with the Lude, so I just want to cover the essentials and anything I can't do in my own garage. Any help would be greatly appreciated. Thanks!
~Bob
Old 02-29-2004, 08:59 AM
HondaPreludeVT
HondaPreludeVT's Avatar
water pump generally is replaced at the same time. i dont think its because they wear out at the same time but just because you have to remove the timing belt to replace it so doing it later on will cost you twice as much in labor.
Old 02-29-2004, 09:34 AM
EliteBob13
EliteBob13's Avatar
So what am I looking at roughly for replace of timing belt and water pump?
I can do the spark plugs myself...should I just stick with the factory plugs or are there better plugs out there I should look at?
~Bob
Old 02-29-2004, 01:07 PM
ludeboom
ludeboom's Avatar
~Bob
timing belt and water pump will range from 450 - 700.
dealer is probably closer to 700, but watch out for the average mechanic, 90% of them dont know a goddamn thing about honda DOHC engines.
if its a vtec u must use NGK platinum plugs designed for the car. there is a noticeable difference
si and s are probably platinum also but you can use champions and bosch if u want.
~boom
Old 03-02-2004, 01:19 PM
fastball
A little chin music
fastball's Avatar
Location: Cleveland, Ohio - Rock 'n Roll capitol of the World
Water pump, timing belt, accessory belts (2), cam adjustment (recomended since the engine is torn appart anyway), spark plug replacement.
450-700 is about right.
Old 03-02-2004, 03:19 PM
ludeboom
ludeboom's Avatar
the engine is torn apart? its just the timing cover, valve cover and drivers engine mount, you dont have to remove the head
cam adjustment :eh:
do cams skip teeth on the belt that often...
or do you mean valve lash adjustment?
~boom
Old 03-02-2004, 05:11 PM
fastball
A little chin music
fastball's Avatar
Well, yeah, but that's enough work as it is, don't you think? I mean, it's all torn appart in the engine bay so you might as well do everything you need to right then.
cam adjustment :eh:
~boom
Oops, sorry..... I meant valve adjustment. You still have to remove the valve cover to do the belt routing easily anyway (at least we did when my uncle and I changed mine). Still, you might as well do the valve adjustment.... it does make a difference and it surprised me by how much a difference it makes.
Old 03-03-2004, 08:42 AM
EliteBob13
EliteBob13's Avatar
What is involved with the valve adjustment?
Old 03-03-2004, 12:20 PM
fastball
A little chin music
fastball's Avatar
You need a set of feeler gauges that have the correct gap for each valve spring (16 of them). You will also need to know what the factory spec is, as you do NOT want to tighten more than the spec. It's not hard, just time consuming..... you have to loosen the adjustment screw with one screwdriver, then slide the feeler gauge at the correct setting under the slot, then with a different screwdriver tighten the adjustment screw untill it just touches the gauge, then tighten the adjustment screw. Do that for each valve.
Old 03-03-2004, 01:58 PM
ludeboom
ludeboom's Avatar
obviously all 8 intake valves are the same
and all 8 exhaust valves are the same.
the chiltons/haynes/helms etc. all have decent instructions and specs for clearance.
for the h22a/1 its .006-.007 inches for intake
and .007-.008 exhaust...
but you never mentioned which engine you have sooo...
~boom
Quick Reply: 90K Maintenance?
