clutch update
Old 07-31-2002, 08:28 PM
JackoliciousLeg
root
JackoliciousLeg's Avatar
Default clutch update
For those of you that have been following my clutch saga, thanks for all the input... it's helped a lot.
Today, I pulled the rubber sleeve off of the clutch slave cylinder and there was a small puddle inside about half a teaspoon full. I posted this earlier:
My clutch started feeling weird, as in it engages lower to the floor now. I have to pull VERY hard to get the car in and out of gear. I changed the clutch and tranny fluid. It's not the synchros cuz it happens in all gears. When the car's off, it flies through gears. I don't think the clutch is enaging/disengaging all the way. I haven't seen any leakage into the cabin (which is where i understand the master cylinder leaks). The clutch pulls nice and hard. No slippage.
I didn't notice a drop in clutch fluid level, but do you think this is the cause? If I change it, will it change the way the clutch feels dramatically? If not, how do I adjust the engagement point? Maybe I'll just do it and see
sharktlp
92+ Civic/EL & Del Sol
9
12-23-2003 07:00 PM
keefungliu
Engine Swaps, Tech & Tuning
12-19-2003 03:29 PM
DMA94ls
3
07-19-2003 05:36 PM
midwestgsr
2
04-29-2003 09:04 PM
Quick Reply: clutch update
