Transmission s2000
EX-R ACCORD
Transmission s2000
I'm working on a school project. To be exact i'm designing an transmission for the S2000. But in order to so, i would need some blueprint or a detailed image of the architecture of this type of transmission.
Is there anyone that could help me out on that. Is there any website that could be helpfull for me?
Thanks
Jodip
Thanks
Jodip
for starters, go to www.s2ki.com and search around on there, if nothing else someone there will be able to guide you to a site.
The S2000 uses an all-new, longitudinally mounted, 6-speed manual transmission, which is built for high performance. Its close-ratio gearing ensures strong performance in every gear, and the shift linkage is very direct, with short, precise throws. Double- and triple-cone synchronizers reduce shift effort, and a separate lubrication pump adds to transmission durability
Other high-performance features of the S2000 drivetrain include a compact pull-type clutch, a lightened flywheel, a highly rigid, one-piece propeller shaft and rigid axle shafts -- all designed to reduce drivetrain flex to an absolute minimum. The Torsen limited-slip differential is a highly efficient torque-sensing, clutchless type that smoothly transfers torque to the wheel with the most traction, whether cornering or accelerating in a straight line.
RaVen_CiviC
92+ Civic/EL & Del Sol
34
09-24-2004 06:11 PM
AcuraFanatic
News & Rumors Archives
15
09-06-2003 07:14 PM
