H22a4 turbo set up ?
Old 02-09-2004, 10:19 PM
Pre1ude
Pre1ude's Avatar
Default H22a4 turbo set up ?
Hello, I own a Prelude SH 98 and I want to uprade to a custom turbo kit.
I don't want to work in the engine yet, so I would like the best set up for best HP, that would still be good for full engine upgrade. Should I go for a T3/T4 and what kind of wastegate ? I know just a bit so thanks for help !
Old 02-09-2004, 10:49 PM
ludeconduct8
ludeconduct8's Avatar
unfortunately for best HP you are going to need to upgrade the engine internals. upgrading your bottom end is insurance for yourself.
Old 02-09-2004, 10:54 PM
monkey
#212
monkey's Avatar
unless you're running some tiny amount of boost, as some people have survived for a while on stock internals running ~6psi
Old 02-10-2004, 03:01 AM
drift
Flaccid Member
drift's Avatar
ATTS doesnt like more than 200ft/lbs of torque applied to it.
Old 02-10-2004, 11:32 AM
Pre1ude
Pre1ude's Avatar
Default What do you mean ?
Cause of the ATTS, I can't have a goord turbo kit with lots of hp ? So what should I do ?
Old 02-10-2004, 11:48 AM
Snoopy
been there done that
Snoopy's Avatar
disable atts. if its possible. ludes arent my thing. h: :thinking:
Old 02-10-2004, 11:54 AM
HondaPreludeVT
HondaPreludeVT's Avatar
definatly resleeve the block if boosting over 10 pounds. the open deck on the a4 makes for weak cylider walls. darton makes an open to closed deck conversion for the h22a4
Old 02-10-2004, 01:39 PM
Pre1ude
Pre1ude's Avatar
Default So H22a4 are the weakest H22 ?
Is that what you're telling me ? So how much hp can a H22a4 andle ?
And what about the ATTS, what should I do to boost my car without having problem with it ? Thanks for help guys !
Old 02-10-2004, 03:03 PM
5hift
Hades: 2.2L DOHC VTEC
5hift's Avatar
H22A4's can handle a shitload of boost, you just have to rebuild the bottom end and upgrade ur internals. If you keep it stock and wanna run a turbo, you won't be able to run much psi.
Old 02-10-2004, 04:56 PM
ludeboom
ludeboom's Avatar
yes the h22a4 is the worst block for high HP turbo
mainly cause of the open deck
get a h22a/1 and sleeve it, add forged rods + pistons and ur done with the block
cam gears for the head, to dial out overlap...
some bigger injectors, the turbo of course, a tial wastegate...
etc
and the electronics
about $4000 from now you will be making good power
~boom
Quick Reply: H22a4 turbo set up ?
