92-96 prelude dohc
Old 02-09-2004, 03:54 PM
B18_Civic
B18_Civic's Avatar
Default 92-96 prelude dohc
what is the head stamp code for the f22a1 and f22b?
thanks
Old 02-09-2004, 04:04 PM
BigLew
BigLew's Avatar
Those are the stamp codes and the F22A1 is SOHC.
Old 02-09-2004, 05:06 PM
4thgenlude
4thgenlude's Avatar
h23 is the DOHC prelude
Old 02-09-2004, 05:15 PM
BigLew
BigLew's Avatar
Yes but you weren't asking about the H23.
Old 02-10-2004, 05:58 AM
B18_Civic
B18_Civic's Avatar
honda made a f22a1 for the accord (90-93)that was sohc and a f22a1 for the prelude S dohc (92-97)
it might just be my info, here is the site i got this off of
http://www.hondaswap.com/forums/inde...howtopic=29825
Old 02-10-2004, 06:22 AM
5hift
Hades: 2.2L DOHC VTEC
5hift's Avatar
How can one be SOHC and the other be DOHC when it has the exact same engine code?
Old 02-10-2004, 09:51 AM
BigLew
BigLew's Avatar
I don't believe that is correct anything I have ever read inlcluding literature from Honda says that the F22A1 is a SOHC engine and it was not offered in Preludes past 96 models. 97 is 5th generation and has no S in the U.S.
The JDM F22B is a DOHC engine and basically it's almost identical to the H23 engine but with an 85 mm bore instead of 87 mm.
Old 02-10-2004, 01:47 PM
4thgenlude
4thgenlude's Avatar
USDM 4th gen (92-96)prelude engines
f22=SOHC no-tec, S
H23=DOHC no-tec, Si
H22=DOHC v-tec, Sr-V or Vtec
Old 02-10-2004, 08:56 PM
B18_Civic
B18_Civic's Avatar
ok im sorry, then i should ask what is the stamp code for the head of a f22b
Old 02-11-2004, 02:45 PM
BigLew
BigLew's Avatar
That is the engine stamp code and it's not the the head it's on the block if it's a JDM F22B then it will say "F22B" on it.
Quick Reply: 92-96 prelude dohc
