ignition key
ignition key
Help. My 93 key does not want to come out of the ignition.
About 1/2 the time it slide past tumbler with no problem.
Then it get stuck on the "1" and WILL NOT come out.
After about 15 mn of trying (and blisters on my fingers from turning) it will the slide out also.
Any hints - tricks - ideas???
Banned
Location: Whitechapel (Not really, goes with the theam)
If its an auto. make sure its reading that its in park.
last year when it got cold. the little spring in the shifter would get cold and not push the little bering into the "PARK" mode telling the car it was in park. The parking pin would set adn the car wouldnt move. but the dash wouldnt show that it was in park. therefor not letting me remove the key.
Keysstuck in ignition when cold
I have a 1990 Accord and my keys won't turn to the I position if it is really cold outside. The key will not come out until the light around the "P" on the dashboard comes on. This is usually ten minutes or so later and i can here a click when it comes on ... How do I fix this...Where is the spring and can it be replaced ....Please help me...THANKS
I also would like to know how to fix.
We have to wiggle the shift, someines pulling back on it till the light comes on. Sometimes turning car off and back on.
The box for the park click in under the area where the ash tray should be. If anyone knows how to fix - or any other shortcuts,
let us know. Its a pain to drive. Ive been stuck before waiting for the light to come on so I can get out of the car finally.
Thank - all info is helpful.
A couple of things:
1) See if you can get a new key made. A lot of times it's because of a worn key. Take your regisition and your ID to your local Honda dealer.
2) Coule be the ignition switch. This is an expensive fix though. Either the key clylinder or the switch right behind the tumbler (there is a spring inside the switch).
I don't think taht it is the ignition switch because i already have had that replaced.... I really just want to know how to fix it. Does anyone know where the spring is that the ripper was talknig about???? Please help me.. It is soooo annoying, esp. when i am running late to work and i have to sit in my car for ten minutes
