| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Honorary Moderator Alumni
2000 Honda Civic Si moonroof leaking.
Sponsored by: KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO! Autocross Help Page |
| Sponsored Links | ||
#2 |
take it back and demand new parts..or a new car
#3 |
Well I can't since the service was performed 2 years ago.
#4 |
A little late of reply but...
Sunroof leaks...there are drain holes in the sunroof, two in the front in the corners, and two in the back. I have an integra and had the same problem, it is becasue after a while the drain holes get plugged. Use an air compressor, or straightened clothes hanger to clean the drain holes. The front ones drain right behind your front wheel wells, Then the rears drain behind your rear whell wells. You can't get to the rear ones from the sunroof, but if you take off your rear bumper...there are several ways, you should find rubber hose type things that poke out from the body of your car. Stick a clothes hanger up those, and twist around, but be kina careful, just in case. When I did this water began flowing like niagra falls, it was amazing...no more leaky leaky.
#5 |
Honda tech/eprom hackr
I wouldn't use a coat hanger, just blow a little compressed air in the holes and you should be good to go
"Yes sir, your next service will be the 60k/transmission replacement" "Ever wonder why the ppl with the least amount of technical knowledge get to tell the ppl with the most amount of knowledge what to do?" |
#6 | |
Quote:
-g
2002 Audi S4 1992 Honda Accord LX (commuter car) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
