good and bad about cams
list all of the good and bad things about cams in general like will it shorten the engines life and that sort of thing
been there done that
good:
more power
bad:
bumpy idle
requires tuning on dyno for max power
effects fuel economy
some of the things depend on the cam your getting. it depends on the cam on whether or not you'll need new springs, retainers, etc. and how high you'll be revving. one thing to consider is where you want the power. low-end, mid-range, high-end, or throughout the entire rev range.
more power
bad:
bumpy idle
[QUOTE]Originally posted by Snoopy
[B]good:
more power
bad:
bumpy idle
What kind of power gains do you want? Snoopy pretty much summed everything up...although with most aggressive aftermarket cams they require a bit more care than the factory vtec cams (frequent valve adjustment, etc.) Also in general the more aggressive cams make power up high, so not only do you need to rev the piss out of your motor but you also need to spend more money on building it to run at those rpms. Running at higher rpms will also shorten the engine life...but this is a risk all us honda-powered drivers take
Shingo
[B]good:
more power
bad:
bumpy idle
Shingo
well i do plan on either low compression turbo or high compression all motor non vtec and run 13's by the time i am done with it (10 years down the road) the only thing i am worried about with turbo is detonation or how ever you spell it. i know that it is a common thing with turbo right?? and i dont know anyone around here with a dyno so ill have to find someone and i got alot of work to do but i like the idea of all motor just b/c i can **** wit people who have s/c and turbos and eat em alive wit my cute lil baby
GO GIANTS!
With any heavily modded ride....TUNING is the most important. Whether it be all motor or turbo. Running a dyno is crucial. Running a turbo is of course cheaper but more delicate to tune. All motor will be expensive to be able to hang with a turbo. However, both routes do shorten you engine life. IMO I like all motor for the same reason you like it....it gives me more satisfaction knowing i beat a turboed car.
Turbo Mafia Soldier
dnt94civic
92+ Civic/EL & Del Sol
18
11-13-2002 10:10 AM
