How much hp will I get from a header?
Im driving a f_cking egg
This has been covered 1,000,000 times, but I was wondering because I already have some aftermarke parts- meaning I think my stock exhaust mani is holding me back.
I have a B18c1 with a new fuel pump (walbro 190 lph) and rewired it straight to the battery with 10 aug wire (more lph), I have a catback 2.25 exhaust, and an open Blitz filter.
My question is how much hp gains will I get and which header is the best? I'm thinking some kind of 4-1 like that jdm dc or something. Please tell me what you think I should get.
been there done that
realistically, maybe 2-5 whp from the majority of mass produced headers on the market. with the bigger headers with 2.5 in collectors and stepped primaries and sequientially paired primaries and things like that, i've seen dyno charts of anywhere from 10-20 whp increases.
Damn thats it? I'm trying to decide what I should do to get my car in the 13s. I guess a header doesn't seam worth it. Maybe I'll look into CTR cams or something. I'm trying to figure out best bang for the buck for NA. What do you suggest, Snoop?
seriously, a good header IS worth it! look more into header-tech headers for 700.00 or SMSP for 1000 bucks plus but these headers will definitely make a difference. do more research on those two, many people are satisfied with those two.
here's a good article
Wannabe yuppie
Honestly I wouldn't be able to justify spending 700 bones or more on a header unless it was being put on a motor that would be able to take advantage of it. A stock internals B18C1 is not such a motor.
For now a DC JDM 4-1 would be a pretty good idea. Just remember that you get no benefit from the 2.5" collector unless you redo the whole exhaust system to 2.5". That means replacing the cat with a 2.5" high flow one, and having custom 2.5" exhaust pipes bent back to a muffler (preferably with a 2.5" inlet).
I would rather spend the coin on a complete 2.5" system than the super-spiffy headers out there like Hytech, etc.
Nurburgring junkie
I highly recommend going with a J-spec header. It will give you a signifigant power increase, while like snoopy said in his first post, an A-spec header wil only net 2-5 hp.
To answer your question of which header is best, HyTech and SMSP are. And yes, they are worth the wait and money.
Originally posted by pythonscott
I agree with replacing the cat to a high flow, but I disagree that a 2.5 catback exhaust needs to be used (though it wouldn't be a bad idea) and here's why: the exit on the JDM collector isn't really 2.5... it's more like 2.25 and the A-spec header exit is around 1.75. So using a 2.25" cat back really doesn't create a bottle neck like you'd think it might.
Do you guys know if most of these 4-1 headers are easy bolt-ons to gsrs? Because like I said, I need to beable to remove it easily for smog.
