Does anyone have a helms for 99 integra
Does anyone have one for a 99 integra on the computer that they could zip to me? I just bought a integra and I am not familiar with this year.
thanks
thanks
been there done that
Don't click the link. It doesn't seem to be up. Is there certain information you are wanting from it? I have one sitting next to you that I can attempt to help you out with.
I need torque specs for some things. It is a 99 integra LS B18B
I need specs for :
Cam keepers
Head bolts
engine to transmission
valve clearance specs should be about .007 or something
crank pulley torque spec
thanks
I need specs for :
Cam keepers
Head bolts
thanks
Camshaft holders: 7.2 lb-ft
Camshaft holder plates: 20 lb-ft (apply engine oil to bolt threads. Temporarily tighten the bolts, then tighten completely in the following order:
12 - 9 - 5 - 1 - 3 - 7 - 11
14 - 10 - 6 - 2 - 7 - 8 - 12
As a point of reference, 1 and 2 are your center bolts on the camshaft holder plates.)
Head bolts: This is a two step process. Tighten all bolts in sequence to 22 lb-ft. Then, tighten them in the same sequence to 63 lb-ft. (also apply engine oil to the bolt threads and under the bolt heads)
Lower transmission mounting bolts(2): 47 lb-ft
Rear mount bracket bolts(2): 87 lb-ft (these are next to one of the lower transmission mounting bolts)
Upper transmission mounting bolts(3): 47 lb-ft
You did not specify which valves so...
Intake Valve Stem-to-Guide Clearance:
- Standard (New) 0.05-0.11mm / 0.002-0.004 in
- Service Limit: 0.16 mm / 0.0006 in
Exhaust Valve Stem-to-Guide Clearance:
- Standard (New) 0.10-0.16mm / 0.004-0.006 in
- Service Limit: 0.22 / 0.009 in
Crankshaft Pulley Bolt: 130 lb-ft
Hope that helps...
Hope that helps...
hey man, do you have an aol, or other e-mail, i can fire a copy off to you...actually it is for a 1994 teg, but it is all roughly the same...better then nothing, anyone that wants a copy, just let me know, if enough poeple want it, then i might just post it on a free web server, or anyone who will host me any way... i aslo have one for '96-'98 civic if any one wants it... let me know...L8er actually, it is the factory service manual..same as helms i think, either way it is still god when it comes to our cars
*peace out*
*peace out*
That would be great if you could zip me the file. My email is pimpingacura@hotmail.com Thanks a lot.
I can get it out to you, but your hotmail will never take it.
It's 38 meg zipped...
Mail me, andre_chouinard@hotmail.com and ill post it somewhere for ya.
