dash panel removal
dash panel removal
I was wondering if anyone here has removed the panels from the dash on a 01 rsx type-s. I got the rings off the passenger side vents and the door handle bezels but I can't seem to get the 1 thats on the drivers side that covers the vent there. Looks like it might be screwed in from behind. Also the 1 that covers the climate controls. EDIT/UPDATE; ok figured out how to remove them, there are 2 big clips on the backside of the drivers panel, you will need to pry against them to ensure that you don't crack the panel. The center console 1 is not to bad, there are 2 1 upper and 1 lower on that panel near the gauges that you need to be careful of, other than that it pops out pretty easily.
