Exhaust Upgrade, CEL now on
Old 09-12-2007, 12:52 PM
Schliti
Schliti's Avatar
Default Exhaust Upgrade, CEL now on
I Just installed a header and down pipe that removed the cat two days ago and now my Check engine light is on. Anyone run into this before? Car still runs great.
Old 09-13-2007, 08:21 PM
Snoopy
been there done that
Snoopy's Avatar
there's your problem
Old 09-14-2007, 09:36 AM
D166thgen
CAPiTA
D166thgen's Avatar
When you removed the downpipe, you removed the o2 sensor embedded in it in the process without knowing it. You should have known this before you decided to install a race header. You should have had to unplugg the o2 sensor from the downpipe to disconnect it at all anyway, so theres your first clue. If you did install the o2 sensor back on, which you may not be able to with a race header (i do not know for a fact), you will probably still get a code because of the absence of the cat. Not to mention, pulling off your cat, regardless of whether you have a race header or just a test pipe will probably throw a code because you will be under emissions standards.
Old 09-16-2007, 03:11 PM
WilsonC4
WilsonC4's Avatar
Even though you're not under emissions standards your Check Engine Light shouldn't come on.. It's because of the o2 sensor like D116thgen said.
If it runs fine and it should.. leave it.. since you want the race header..
Old 09-19-2007, 09:41 AM
D166thgen
CAPiTA
D166thgen's Avatar
"If it runs fine and it should.. leave it.." FTW unless you live in california, where smog emissions are tested for legality.
