10-17-09, 05:59 AM
Starting issue
I got a 93 Prelude 5 speed. For some reason, occasionally, it has a little bit of trouble starting. First I thought it was my battery. I changed it and the problem wasn't solved. Then I thought it could be my starter. Replaced it, still same problem. So now I'm stuck.
Here is what happens:
When I try to start the car, all the dash lights come on but the engine won't crank.
Releasing the clutch and pressing it back in usually does the trick to get it started. Im thinking it might be the little ignition switch by the clutch pedal. But before I rip that thing out is there anything else that might be causing this?
Thanks for your time
Chuck Norris is the reason Waldo is hiding.
