15 inch sub, 4 channel amp, alot of wires, distro blocks etc (PA)
Please email me all offers or pm me. Pictures can be sent via email. I'll ship everything besides the sub and amp just because I don't trust the amp getting anywhere undamaged.
1 Audiobahn AW151t 15 inch subwoofer - less then 6 months old (Specs and pictures at bottom)
1 Q-Logic Box for the 15 inch subwoofer - (Less then 6 months old, has sub installed)(QLH-2.2515SS)(Specs and pictures at bottom)
1 Audiobahn 4 Channel amplifier, intake series (A4004t)(Specs and pictures at bottom) (The air intake does not work anymore but everything else works great)
Various car stereo installation pieces:
25 feet of 4 gauge wire (USED)
1 Battery terminal (NEW)
2 In-line fuse holders (USED) pending
1 Distribution block (Description below)(NEW)
1 Street Wires Fused Distribution block (Used)
1 2 Channel no-name RCAs (USED) pending
1 4 Channel Rockford RCAs Dual Twist (ROCCPDT46)(USED)
20 Feet of remote turn on wire (proably like 14 gauge)(USED)
20 Feet 8 Gauge wire (USED) pending
Alot of speaker wire (USED)
Subwoofer Specs:
* Optimized for Maximum Sound Quality / SPL
* PHAT 2” Foam Surround
* 120 oz. Magnet
* Non-Pressed, Non-Transfer Paper Cone
* KM3 Coated Cone for Low Cone Distortion
* Flame-Designed Cast Flame Basket
* High-Temp 2.5" ASV Voice Coil Former
* Multi-Connect Lug-Lock Terminals
* Mounting Depth: 7 1/8”
* Hole Cutout: 14”
* Outer Diameter: 15 1/2”
* Size: 15 inch
* Rec. Sealed Box Dims: 1.25 - 3.25 cu.ft.
* Rec. Ported Box Dims: 1.65 - 3.7 cu.ft
* Free Air Usage: not recommended
* Sensitivity: 94 dB
* Frequency Response: 22-700 Hz
* Recommended RMS Power: 650W
* Peak Power Handling: 1300W
* Impedance: 4 ohms subwoofer wiring options
Sub Box Specs:
» Type 2 hatchback style enclosure for one 15" subwoofer
» 5/8" medium density fiberboard construction with gray carpet covering — additional 3/4" front panel supports woofer
» nickel-plated, spring-post speaker terminals
» optional interchangeable baffles accommodate non-round subwoofers
» QXs mounting ring
» internal volume: 2.25 cubic feet
» dimensions: 26-1/2"W x 17-1/2"H x 17"D1 x 12"D2
Amplifier Specs:
* Class A/B MOSFET Circuitry
* PWM MOSFET Power Supply
* Semi-Double Sided Glass Epoxy Circuit Board
* Variable 18 dB Low-Pass & High-Pass Crossovers
* Variable Subsonic Filter
* Switchable 18 dB Bass Boost at 45 Hz
* 3-Way Protection Circuitry
* Cobalt Blue Illumination
* High Gloss Chrome-Plated Finish
* Nickel-Plated Block Terminals
* Air Induction Fan Cooled
* Preamp Outputs
* Optional Remote Voltage Monitoring
* Optional Remote Bass Boost Control
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 50W x 4
* THD at 4-Ohm RMS Power: 0.02%
* Bridged RMS Power @ 4 Ohms: 200W x 2
* Speaker Level Inputs: no
* Preamp Outputs: yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 or 18 dB
* Frequency Response: 10-40,000 Hz
* Signal to Noise Ratio: > 100 dB
* Fuse Rating: 2 x 30 amps
Specs for distribution block:
Lighting Audio Bolt Series features solid machined brass construction with hard gold plating for reliable connectivity. The BD3 is ideal for connecting amplifiers and fused distribution blocks. It feature a clear base and snap-off cover with etched logo. The BD3 accepts two 0/1 gauge inputs and three 4 gauge outputs.
Bookmarks
