2 Alpine Type R 12in In Box With Amp
I have two alpine Type R 12in subwoofers in a box being run by a 1600W sony xplod amp. Everything works perfect and it comes with all the wires needed to get it going. Best sounding subwoofers ive ever heard, im just getting rid of them cause im going for speed now and these subs are just too much dead weight.
I got the subs brand new for 250 a piece the box for 150 and the amp for 200 all together with tax and everything i spent about 925-950! My loss is your gain. Eveything is in perfect running order and may i say that these subs are by far the best sounding and hiting subwoofers ive ever heard. Yea my friends have their systems and some are louder than mine but theirs all sound like crap.
MAKE AN OFFER - NO LOW BALLERS
Key Features
• Frequency Response:
24Hz – 2kHz
• Dual Voice Coil Design
• Kevlar Reinforced Pulp Cone
• High Excursion 1” Santoprene® Surround
• Dual Custom Progressive Nomex® Spiders
• Integrated Tinsel Lead Design
• Custom Cast Aluminum Frame
• Extra Length Extended Pole
• Flared Pole Vent
• Bumped Backplate
• Heat Transfer Plate
• High Strength Brass Voice Coil Bobbin
• Double Stacked Magnets
• Heavy Duty 8ga. Push Terminals
• Oversized Parabolic Dustcap
• Magnetically Optimized Motor Structure
• Designed and Engineered in the USA
Features:
Woofer
Bumped Backplate
Compound Radius Curve Pole Geometry
Custom Cast Aluminum Frame with Integrated Heat Transfer Plate
Dual Progressive Oversized Nomex® Spiders
Dual Stacked Magnets
Flared Pole Vent
High Excursion 1" Santoprene Surround
Magnetically Optimized Motor Structure (Pat. Pend.)
Specs:
General-Subwoofers
Diaphragm Material : Kevlar Reinforced Pulp
Magnetic Weight : 89.4oz.
Mounting Depth (top mount) : 178mm (7”)
Mounting Diameter (top mount) : 275mm (10-7/8”)
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.7 – 1.0 cu. ft.
Spider Material : Nomex
Voice Coil Diameter : 50mm
Power Handling
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Thiel Small Parameters
Coil Height (Hvc) : 36.7mm
Cone Area (Sd) : 467.59 sq. cm
D.C.Coil Resistance (Re) : 1.8 ohm + 1.8 ohm
Electrical Q (Qes) : 0.40
Equivalent Suspension Stiffness (Vas) : 58 liters(2.04cu.ft.)
Free Air Resonance (Fs) : 27Hz
Frequency Response : 24Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 2 ohm + 2 ohm
Inductance (Le) : 2.41mH at 1kHz (0.84mH at 20kHz)
Linear Excursion (X linear) : 13.35mm
Maximum Excursion (X peak) : 26.7mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 8.68
Sensitivity : 87 dB/W/M
Total Loudspeaker Q (Qts) : 0.38
Amp info
Sony X-Plod XM-DS1600P5
(Look it up on the internet....it retails now for 200 at the least!!!)
Features:
1600W max power
500W x 1 RMS into 4 ohms, 20Hz - 100Hz at 0.2% THD
900W x 1 RMS into 2 ohms, 20Hz - 100Hz at 0.6% THD
Class D
Subsonic filter
Remote subwoofer level control
Variable 50-300Hz low pass filter
40Hz EQ boost
Line level through-put
MOSFET output stage & power supply
RCA & speaker level inputs
Specifications:
Circuit system -- Class D Technology
Power supply -- Pulse
Maximum outputs -- 1000 W (at 4 ohms)
Maximum outputs -- 1600 W (at 2 ohms)
Rated outputs (at 14.4V) -- 500 W (20 - 100Hz, 0.2% THD, at 4 ohms)
Rated outputs (at 14.4V) -- 900 W (20 - 100Hz, 0.6% THD, at 2 ohms)
Frequency response -- 5 Hz - 300 Hz (±3dB)
Harmonic distortion -- 0.06% or less (at 100 Hz, 4 ohms)
Input level adjustment range -- 0.3 - 6V (RCA pin jacks), 1.2 - 12V (High level)
Low-pass filter -- 50 - 300 Hz, -12 dB/oct
Low boost -- 0 - 10 dB (40 Hz)
Inputs -- RCA pin jacks, High level input connector
Outputs -- Speaker terminals, Through output pin jacks
Speaker impedance -- 2 - 8 ohms (stereo)
Power requirements -- 12 V DC car battery (negative ground)
Power supply voltage -- 10.5 - 16 V
Current drain -- 50 A (at 4 ohms, rated output)
Approximate measurements -- 13-11/16" x 2-1/4" x 13-/8" (wxhxd) not including projecting parts and controls
Weight -- Approx. 3.8 kg (8 lb 6 oz)
Dimensions -- Approx. 347 x 57 x 339mm
Key Features
24Hz – 2kHz
• Flared Pole Vent
• Bumped Backplate
Features:
Woofer
Bumped Backplate
Flared Pole Vent
Specs:
General-Subwoofers
Power Handling
Amp info
Features:
1600W max power
Class D
Subsonic filter
40Hz EQ boost
Specifications:
ill tell you what civicsieg......you give me 15 plus you suck on my left nut....no wait make that the right nut....and then you can have it. Get back to me on this one.
