FS: OBD2a and OBD2b to OBD1 conversion harnesses.
1.5L boost whore
$75 + shipping from 01507. Charlton, MA
This lets you use a 92-95 OBD1 ecu (P28 sohc vtec) into 96-00 Civics, Integras, Preludes, Accords, and CRVs. This is a must have for a Honda/Acura owner who wants to use a chipped OBD1 ECU.
You can also use this if you swap an OBD2a/OBD2b motor and wiring harness into your OBD1 car. perfect for those B series swaps into 92-95 Civic hatchbacks.
NOTE: Wires and connectors in the harness may be different colors than pictured. This WAS an actual harness I made.
if you need details, PM me here or email me at chrisswebdesign@verizon.net
If you need references, im on www.HondaSwap.com as TurboMirage, www.Mirageforums.net as red93mirage, and www.4g61t.org as red91colt.
Life after death
I'm interested in a conversion harness and I was wondering if anyone could answer my question.
I have a 2000 Integra LS. (OBDIIb)
How do you bypass the factory immobilizer?
If I were to swap my ECU with a conversion harness would I be straight. Do I need to have an extra Acura ignition key without the chip in it? How do I make this work?
1.5L boost whore
the immobilizer has an external module but will be inactive if you use an OBD1 ECU. you can use your original key.
if you need an ECU as well, I can do $240 shipped for an ECU with any program on the chip, Full Throttle Launch, and Check Engine Light shift.
