Other Honda & Acura News Automotive news from around the globe.
DIY Leak-Down Testing - Wrenchin'
Old 01-20-2009, 10:30 PM
Nelson
Administrator
Nelson's Avatar
Default DIY Leak-Down Testing - Wrenchin'
Build one today. Find out if your engine's shot tonightBesides all of the moving parts and complicated-looking pieces of metal, an engine really only needs four things to run: fuel, air, compression, and a spark. It sounds easy enough, but once there's a problem with any one of these four things the chances of your engine actually running become pretty slim. The first tool many do-it-yourselfers, and even mechanics, grab when an internal engine problem is suspected is the compression tester. While the compression tester serves its purpose, it'll never be able to pinpoint the actual problem. Sure, it can tell you that cylinder number three has just taken a crap, but it won't tell you why. Is it the piston rings or a valve? How about a cracked cylinder wall or a blown headgasket? It's times like these you'll need a leak-down tester.
Photo Gallery: DIY Leak-Down Testing - Wrenchin' - Honda Tuning Magazine
Read More | Digg It | Add to del.icio.us
More...
