Go Back   Honda-Acura.net > Open Forums > Automotive News & Rumors > News & Rumors Archives
New! Use your Facebook to securely log into this site, click logo to login
News & Rumors Archives Useful threads, previous Cars of the Week, and more.
View Poll Results: What Do You Think of the Changes?
I like the '04 better 2 12.50%
I liked the '03 better 10 62.50%
I like them both 4 25.00%
:gives: 0 0%
Voters: 16. You may not vote on this poll
Thread Tools Display Modes
Old 09-03-03, 05:55 PM   #1
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Send a message via AIM to 98CoupeV6 Send a message via Yahoo to 98CoupeV6
Updated 2004 Acura MDX
Exterior
Interior
Close-Ups
Press Release
The 2004 Acura MDX luxury sport utility vehicle receives updated styling, new safety systems, additional horsepower and an assortment of new features. The new 2004 MDX sports redesigned front and rear fascias, redesigned alloy wheels, a new Side Curtain Airbag system that helps to protect occupants in all three rows, and interior upgrades including enhanced interior lighting and, on models with the available Touring Package, power-adjustable driver's lumbar support.
"The public knows a great thing when it sees it and the MDX has been one of the most sought after luxury SUVS on the market since it was introduced in 2001," said Dick Colliver, executive vice president, auto sales. "With the numerous changes we've made to the 2004 model, it should be hotter than ever."
The 2004 MDX features sportier styling designed to more accurately reflect the strength of its high performance powertrain. The signature Acura family grille, which now sports a sophisticated satin chrome finish, serves as the centerpiece for a new, more tapered front fascia. A redesigned headlight treatment features a leaner, more angular design and new projection-type headlights that enhance illumination while accenting the new styling. The front bumper has been redesigned with a new, more integrated chin spoiler that accents the sporty styling and moves air smoothly to the sides of the car for increased aerodynamics. The rear fascia has been updated as well with a new, more sophisticated taillight treatment, and dual exhaust tips. Two new exterior colors, Aspen Pearl White and Burnished Bronze Metallic join the MDX palette for 2004.
The 2004 MDX's 3.5 liter, 24-valve, all-aluminum, VTEC V-6 engine benefits from a new, dual exhaust system that boosts horsepower from 260 to 265 and torque from 250 lbs-ft to 253 lbs-ft. This exhaust system utilizes two close-coupled primary catalytic converters, a secondary underfloor catalytic converter, and larger diameter exhaust pipes. In addition to adding horsepower, the new exhaust system helps the MDX meet stringent ULEV-2 emissions standards. With estimated city/highway ratings of 17 mpg city/23 mpg highway, the MDX delivers better combined fuel economy than most of its luxury competitors.
The MDX features a compact 5-speed automatic transmission with components engineered to provide the durability needed for on-road, off-road and towing use. A wide-ratio design affords a first gear with extra pulling power to start heavy loads and a high top gear for quiet highway cruising. This 4-shaft gearbox utilizes a unique shaft layout that not only reduces size, but also trims gear noise, clutch drag and hydraulic friction.
The 2004 MDX employs a drive-by-wire throttle system that evolved from the NSX supercar. This innovative system eliminates the need for a mechanical connection between the accelerator pedal and the engine, and modulates the throttle during transmission shifts for improved smoothness. It also allows for throttle control to be seamlessly incorporated into the MDX's VSA logic and directs the vehicle's cruise control function.
The 2004 MDX utilizes a unique VTM-4 four-wheel drive system designed to enhance traction on low friction surfaces. Unlike conventional automatic 4WD systems, which react only to wheel slippage, VTM-4 proactively apportions torque from the front to the rear wheels before wheel slippage can occur. When cruising, the system automatically reverts to front-wheel drive for improved fuel economy.
In addition to ample power, the MDX delivers sport sedan-like handling and a smooth, compliant ride. It features a 4-wheel fully independent suspension, 4-wheel disc brakes with 4-channel ABS, dual piston calipers in the front, standard 17-inch alloy wheels and specially designed P235/65R-17 all-season tires to provide stability and responsiveness. Front and rear stabilizer bars, a wide track and a low center of gravity give the MDX predictable cornering response and help maximize cornering capabilities.
Handling is further enhanced through the application of a standard Vehicle Stability Assist (VSA) system that works in concert with the VTM-4 and drive-by-wire throttle systems to provide enhanced control during acceleration, braking and cornering. This 4-channel system orchestrates the throttle and each of the vehicle's four disc brakes to seamlessly integrate traction control, Anti-lock braking, and stability enhancement for increased driver control during acceleration, braking and cornering.
The MDX's interior emphasizes the vehicle's versatile yet refined character with standard-setting levels of luxury and functionality. Three uniquely transformable rows of seats allow the MDX to comfortably seat up to seven passengers. A convenient walk-in feature provided at the right (curb) side of MDX's second-row seat slides the whole second seat forward with the touch of a lever. This feature has been improved for 2004 by extending forward travel 40 percent, making entry and egress to the third row even simpler. Second and third row seats split and fold flat into the floor providing 82 cubic feet of cargo room. Even with all three rows in use, the MDX still offers 14.8 cubic feet of cargo room behind the third row seats.
For 2004, a variety of enhancements have been made to the MDX interior including the addition of brushed metal-look trim on the instrument panel, ambient foot lights, and welcome illumination. A new, Side Curtain Airbag system has been applied to help reduce injury to occupants in all three rows of seats during a sufficient side-impact collision. It deploys from a module in the roof in the event of a sufficient side impact, providing an important and significant level of head protection in the window area. This system also includes a series of rollover sensors designed to trigger the system in the unlikely event of a rollover. Should the MDX begin to tip, the rollover sensors monitor the rate of roll and deploy the side curtain airbags accordingly.
The MDX also features dual-stage, dual-threshold driver's and front passenger front airbags. The driver's airbag adjusts deployment force to one of two rates according to input from sensors which monitor the severity of the impact, seatbelt usage and the position of the driver's seat. The front passenger airbag's deployment takes into account the severity of the crash, seatbelt usage and the passenger's weight. The MDX also offers driver's and front passenger's side airbags with occupant position sensors in the passenger's seat; and the LATCH (Lower Anchors and Tethers for Children) system on the second row of outboard seats to simplify child seat attachment.
New for 2004 is a direct Tire Pressure Monitoring System that uses sensors in the valve stem of each wheel to alert the driver when tire pressure drops significantly below the recommended level. If the system detects that tire pressure is low (32 psi is recommended), the low pressure indicator notifies the driver, while a schematic of the vehicle located in the center meter housing the speedometer indicates which tire or tires require air.
While the MDX is already one of the most comprehensively equipped vehicles in its class, an optional Touring Package adds a variety of premium features. These features include a roof rack; exclusive alloy wheels (redesigned for 2004); an upgraded, eight speaker Acura/Bose Music System with 6-disc, in-dash CD changer; two-position memory for the driver's eat and sideview mirrors, and a front passenger's 8-way power seat. For 2004, the 8-way power-adjustable driver's seat now features power-adjustable lumbar support. The Acura/Bose Music System receives a more powerful 225 amplifier and revised speaker tuning for superior sound reproduction.
The Acura Navigation System with Voice Recognition is available as a factory-installed option on models equipped with the Touring Package. This state-of-the-art
navigation system includes a menu of 217 voice commands, a comprehensive destination guide with over 7 million points of interest, turn-by-turn guidance and coverage of virtually every road in the continental United States. For convenience and safety, the system also includes a rearview camera incorporated into the tailgate, which transmits a rearview picture to the navigation screen when the MDX is in reverse gear.
The Acura DVD Entertainment System is also available as an option on Touring Package-equipped models. The 7-inch LCD screen is mounted to the headliner, just behind the front seats for use by rear seat passengers. The DVD player mounts below the standard audio system and plays over the MDX's sound system or through a pair of cordless infrared headphones. The system can be controlled either by using the MDX's audio controls or from the rear seats through the use of a remote control or the screen's control panel.
Like all Acura vehicles, the MDX comes equipped with a comprehensive 4-year/50,000-mile limited warranty that includes Acura's customer service package.
      Registered and logged-in users don't see this ad!
Register your free account today.
2003 San Marino Red Accord Coupe EX-V6 6MT
IMM244k miles
www.lemons300zx.blogspot.com
98CoupeV6 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-03-03, 08:10 PM   #2
AcuraFanatic
AcuraFanatic's Avatar
Not really liking the tail lamps...sort of a rip of the RX300/RX330 theme...but whatever, it's trivial.
Still a nice vehicle. I like them both.
EM2
AcuraFanatic is offline   Reply With Quote
Old 09-03-03, 08:55 PM   #3
TheOtherDave™
Keeping the faith...
TheOtherDave™'s Avatar
Of the two variants, the tail lighs on the o4 model are so awful, they ruin the whole rear elevation.
If I had to pick between the two, I'll stick with the 03 model.
But then again, I doubt I'll pick an SUV anytime soon at any rate.
david :: supermoderator
:: HAN Integra FAQ:
Borderline antique, but still useful.
TheOtherDave™ is offline   Reply With Quote
Old 09-03-03, 09:11 PM   #4
yianni64
yianni64's Avatar
Send a message via AIM to yianni64
The front is better.
I am too lazy to redo my sig.
yianni64 is offline   Reply With Quote
Old 09-03-03, 09:28 PM   #5
98CoupeV6
98CoupeV6's Avatar
I think the front, rear and interior are huge improvements. I like the job they did.
Query: Why did they spend so much money updating such a hot selling model?
IMM244k miles
Old 09-03-03, 09:49 PM   #6
04 Acura TSX
DOHC iVTEC Power!
04 Acura TSX's Avatar
Quote:
, but what's with the altezza kinda look with the taillights?
The '03 version's tails looks better.
An Acura is a Honda, but a Honda isn't an Acura.
2004 CG Acura TSX 6MT
04 Acura TSX is offline   Reply With Quote
Old 09-03-03, 10:15 PM   #7
white_n_slow
it's my D in a B
white_n_slow's Avatar
Send a message via AIM to white_n_slow
I like the '03 wheels, headlights and tail lights much more. Other than that its pretty much the same car, right? I guess that means I prefer the '03 to the '04.
:edit: The dual rectangular exhaust is a little silly. Looks like its trying to be a yukon or escalade or something.
'92 Civic VX B20 autocross rig: sold for scrap
'85 FJ60 Land Cruiser: OME lift and some wicked rust
'05 SAABaru 9-2x Aero: stock, daily grind
'08 Never Summer Heritage: 158, Flow NXT FR, winter sled
www.eosmotorsports.com
white_n_slow is offline   Reply With Quote
Old 09-03-03, 10:15 PM   #8
j-bloc
no hids?
j-bloc is offline   Reply With Quote
Old 09-03-03, 10:18 PM   #9
kazi
Toyota Racing = Cheaters
kazi's Avatar
Quote:
Gotta keep with tradition. 5 year model cycle with 3rd year a refresh with minor cosmetic changes. Every other model cycle is a platform.
kazi is offline   Reply With Quote
Old 09-03-03, 11:12 PM   #10
AcuraFanatic
Quote:
Originally posted by j-bloc
no hids?
I'm kind of disappointed at that too.
EM2
Old 09-04-03, 12:59 PM   #11
rb6teg
rb6teg's Avatar
Send a message via AIM to rb6teg
I like the new front grill, and I'm not exactly sure about how big of a difference the rest of the front is, but I know that those taillights are HIDEOUS.........what was Acura thinking?!
Humanaut Pittsburgh
rb6teg is offline   Reply With Quote
Old 09-04-03, 10:28 PM   #12
socalprelude
Yeah I don't like the taillights at all, it looks like it is trying to be a wannabe RX. Other then that though its all good, although the taillights are so bad i would pick the 03
1st car- '85 Toyota Corolla 2 dr
2nd car- '92 Honda Prelude
3rd car- '98 Honda Prelude
current- '02 Accord EX
socalprelude is offline   Reply With Quote
Old 09-05-03, 08:05 PM   #13
velfarretokyo
I doubt they spent a significant amount of money to upgrade the MDX. Most of the changes are simple cosmetic component swaps, with relatively few mechanical changes.
But I think its obvious why Acura decided to make changes to the MDX, even though it is hot-selling. Just think of all the entry-level luxury SUVs that have entered the market in the last 12 months that compete with the MDX. You have the Murano, FX35, Toureag, XC90, Endeavor, updated RX330, and Aviator. Then you need to see that the SRX, 9-7, and X3 will coming for the 04 model year. And thats already on top of all the other entry-level luxury SUVs that are in a similar price bracket. I have a sinking feeling someone is going to start whining that some of these aren't direct competitors of the MDX...
velfarretokyo is offline   Reply With Quote
Old 09-06-03, 12:25 AM   #14
j-bloc
btw
thats not bad looking plood lol
Old 09-06-03, 12:53 PM   #15
yianni64
yianni64's Avatar
You'd be suprised at how much those updates cost Honda. The cost of tooling for even such minor changes is very high.
Old 09-06-03, 05:17 PM   #16
KV_
Shift_for yourself
KV_'s Avatar
How come from this angle it looks like a Isuzu Rodeo.
Not feeling the rim treatment, back lights and mufflers either.
But it will still sell well.
For sale 92 Acura Vigor - blown motor. Anybody in Dallas p/u for $450
03 Spec
KV_ is offline   Reply With Quote
Old 09-07-03, 12:11 AM   #17
velfarretokyo
I meant significant on relative terms. No doubt these changes will cost Honda money, but overall its a small price to pay to retain leadership (and sales volume) in that segment. Besides, I'm positive Acura makes good profit off the MDX models.
Old 09-27-03, 01:28 PM   #18
98CoupeV6
98CoupeV6's Avatar
It's now on the Acura website...looks really nice.
http://www.acura.com/models/model_index.asp?module=mdx
IMM244k miles
Old 09-27-03, 01:32 PM   #19
LuckyDog
AccordPower24
I didn't like this at first, but I saw a commercial for it last night and it looks pretty damn good in black.
LuckyDog
.:..::: 2004 Dark Grey Nissan Pathfinder Armada LE 4WD
.:..::: 2001 Silver Volkswagen Jetta GLX VR6 5-speed
LuckyDog is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Honda-Acura.net - Code of Conduct - Archive -
Top
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
