Dodge Demon Roadster Concept – Simple Soul, Artful Attitude Make for Radical Results
http://www.duemotori.com/news/auto_n...Motor_Show.php
Geneva – The Dodge Demon concept is a compact, nimble “roadster with an attitude,” a perfect balance of classic sports car proportion and simplicity blended with modern design and performance.
“While the iconic Dodge Viper is a dream car for many, the Dodge Demon is designed to be an attainable dream car,” said Jae Chung – Dodge Demon Principal Exterior Designer, Chrysler Group. “The exterior design is simple yet bold, featuring an energetic combination of curves and intersecting planes.”
The bodyside of the Dodge Demon main character line flows up and over the front wheel, then drops diagonally to an angular color-keyed vent on the rear fender that directs cooling air to the rear brakes. In similar fashion, the compound rear fender surface curves up and over the rear wheel, sweeping into a broad diagonal plane extending to the taillamp. The resulting muscular fender form projects boldly beyond the main body, underscoring that the Dodge Demon concept is a rear-wheel-drive machine.
The rear surface of the body is divided into three planes with two chamfered outboard planes, dominated by long, tapering trapezoidal taillamps. The taillamps sport translucent red inset lenses that surround LED back-up lamps.
Up front, the signature Dodge crosshair grille is stuffed into an aggressive, menacing, trapezoidal opening that thrusts boldly forward.
Set into elongated angled triangles, the projector headlamps, delineated by bright rings, are set into black chrome bezels, giving the front end mean-looking “eyes” that accentuate the grille opening. Encompassing the upper portions of the front fenders and sporting two recessed air outlets, the Dodge Demon’s hood is hinged at the front, adding a just-for-fun performance-car look and feel.
Featuring an open-spoke design, the wheels are pushed to the corners of the body for a dramatic stance and capable performance. The 19-inch brushed aluminum wheels are set into assertive, asymmetrical openings that reprise the body’s playful combination of curves and planes.
The beltline kicks up at the rear and into the higher deck lid contour, giving the lucky occupants an encapsulated, protective feeling.
“In the manner of timeless British sports cars, the interior of the Dodge Demon is purposely functional, not frivolous,” said Dan Zimmermann – Dodge Demon Principal Interior Designer. “Everything relating to the driving experience is emphasized, while that which is not is made visually secondary.
“The well laid out instrument panel, for example, is familiar, yet modern. Everything you really need – the gauges, circular AC outlets, radio – is encapsulated in a cross-car brushed aluminum bezel that also accentuates the width of the cabin. Secondary controls and features, such as the HVAC knobs and the passenger-side glove box, are located below this bezel,” Zimmerman added.
In a similar functional manner, the floor console is deliberately not a part of, or attached to, the instrument panel. The console is dominated by the squat ready-at-hand silver and black manual shift knob, and its leather boot is set into a bright trim ring. The wide, brushed aluminum console bezel also incorporates the recessed emergency brake handle, with the window switch gear, softly lit cup holders and 12V power outlet organized into a graphically unified shape. The upper portion of the instrument panel, including the cluster brow, is accented by a stitched seam with contrasting silver thread.
“Each of these features is set flush, or nearly flush, with the bezel surface so as to establish a ‘clear zone’ for the driver’s shift arm in all seating positions, with nothing in the way of the driving experience,” Zimmerman said.
The raised plateau at the rear of the console incorporates a covered storage bin – with a lid that serves as an armrest between shifts – while the portion of the console extending under the instrument panel has an open bin handy for incidentals.
The steering wheel employs an aluminum open-spoke design with each of the three spokes intersecting the small circular hub for a timeless sports car look. The wheel rim itself is brushed aluminum on the inside, complemented with stitched vinyl on the outer rim. Immediately forward of the wheel, the four-gauge cluster features classic white-on-black dials with graphics inspired by sports watches. Each circular gauge is set handsomely inside a finely detailed silver and chrome bezel ring, while gauge pointers are colored to match the exterior.
The doors feature durable, vertical grab handles, each anchored to a silver bezel housing the chrome door remote handle. The lower portion of each door features a stylish brushed aluminum bezel that encapsulates the large circular speaker grille and then drops sharply as it moves rearward to form the map pocket outer panel, mimicking a feature line on the car’s exterior.
The Dodge Demon’s seats feature contoured bolsters that are just high enough to provide support when cornering, yet do not hinder ingress or egress. Set in exposed low-gloss carbon fiber shells, the black seats with integral head restraints feature inserts of textured “Momentum” fabric mated to fabric bolsters, with specific sew lines accented by silver thread. Individual brushed aluminum and carbon fiber roll bars are positioned directly behind the bucket seats. With long seat tracks, there is ample storage behind the seats. Additional covered storage is provided in the bulkhead between the seats.
The Dodge Demon concept is an affordable Dodge sports car which merges brand cues of bold design and powerful performance with an open-air “fun-to-drive” attitude.
PRELIMINARY TECHNICAL SPECIFICATIONS
Dimensions are in inches (millimeters) unless otherwise noted.
Engine: 2.4-liter petrol World Engine
Maximum Power: 172 hp SAE (128 kW) @ 6000 rpm
Maximum Torque: 165 lb.-ft. (224 Nm) @ 4400 rpm
Transmission: Six-speed manual
Drivetrain: Rear-wheel drive
Overall Length: 156.5 (3974)
Overall Width (max. @ body): 68.3 (1736)
Overall Height: 51.8 (1315)
Wheelbase: 95.6 (2429)
Overhang, Front: 30.6 (777)
Overhang, Rear: 30.3 (769)
Curb Weight (estimated): 2600 lbs. (1179 kg)
Tire Size, Front/Rear: 58.7 (1491)
Wheel Size: 19 x 8 in.
Outer Diameter: 25.2 (640)
Exterior Color: Bright Amber Pearl
Interior Color: Carbon Black
Apathy Kills
Ditch the airscoops on the rear wheel arches, give it a 5 to 7 cubic foot trunk and build it. And keep the weight under 2600 lbs, please.
Apathy Kills
:chuckles: I'm glad I'm not the only one who remembers that car. h:
This is what a member of another forum wrote about this car, and it kept me laughing for at least half hour.
Anyway, I agree. This car is not impressive. Shameless ripoff of the Z4 and TT. The Solstice makes this car a failure.
Apathy Kills
In addition to being overweight... it has a couple of absolutely moronic ergonomic gaffs.
The window switch fiasco and the near-complete lack of a trunk are enough to knock it out of contention as a sole-car daily driver.
If DCX gets real about the engine options, keeps the weight down and puts in a halfway decent trunk, IMO it is worth trying to compete with the MX-5.
PS: The comment about hp is really meaningless in the end.
It's all about power-to-weight in this class of cars.
176 hp in a 2400 lb car will do fine.
260 hp in a 2900 lb car is IMO the product of sloppy engineering.
