Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
brakes pull to the right
Old 11-05-2010, 09:16 AM
sakitlikod
sakitlikod's Avatar
Default brakes pull to the right
what cause when you brake & pulls to the right in 04 honda odyssey & sometimes steering wheel shakes when braking at high speed ? thx
Old 11-06-2010, 08:55 AM
cruzalekz
cruzalekz's Avatar
front rotors warped (vibration problem)
pulling to the right )(check wheel allignment , check wheel bearing at fronts
Old 11-19-2010, 06:09 AM
sakitlikod
sakitlikod's Avatar
hi thanks for the post. I had my rotors cut, but sometimes the steering wheel still shakes or vibrate.
,also how do i check if the wheel bearing is bad.thx
Old 11-20-2010, 05:16 PM
Carbuff
Carbuff's Avatar
High-speed vibration (no braking) indicates an out-of balance or out-of-round tire or rim. Swap tires front-to-back to see if the symptom changes...if so, it's the tires.
usually wheel bearings make a humming sound (25 MPH and over) that changes when that side of the car is "loaded". That is, a bad left side bearing will hum louder during right hand curves. :awais:
Old 11-23-2010, 03:49 AM
sakitlikod
sakitlikod's Avatar
these are new tires & wheels are not bent.
I felt steering wheel vibrates only between the clearance/play of left to right when I steered the wheel.
Also sometimes steering wheel shakes on hard braking.
Old 11-23-2010, 12:49 PM
Carbuff
Carbuff's Avatar
Could still be an out-of round or balance tire...the tire installers don't always get it right.
Another possibility is that you need road-force balancing. This compensates for the areas of some tires that have less "give". (The tire is balanced on a machine that uses a roller to simulate the pressure of the car)
Old 11-27-2010, 10:41 AM
cruzalekz
cruzalekz's Avatar
check lower control arm bushings and motor mounts
Old 11-30-2010, 06:07 AM
sakitlikod
sakitlikod's Avatar
they looks ok
Old 01-15-2011, 03:48 PM
cruzalekz
cruzalekz's Avatar
