Go Back   Honda-Acura.net > Auto Forums > Minivan, SUV, & Truck
Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
Thread Tools Display Modes
Old 10-23-09, 03:24 PM   #1
TigerJon73
Transmission Fluid Change - '06 Pilot
Hello,
I own an '06 Pilot I use for work. I purchased it new from a dealership in St. Joseph, MO in November of '05 and have about 105k miles on it. I have to say that this vehicle has been a pleasure to own. I have been a Honda guy for about 18 years (followed the good advice from my dad) and between my wife and I we have owned 7 Hondas and one Acura. Knock on wood, we have never had anything close to a major problem with one. My wife currently drives an '08 Odyssey EX-L and it has been fantastic so far.
I recently dropped about $800 bucks at my local dealership for a new timing belt/waterpump, a rear-end diff flush and fill ,and an oil change. In light of this hefty tab, I think I may try to do an ATF refill on my own. I believe I have found the fill-plug (hex head bolt on back of tranny that says ATF), but not sure where the drain plug is (I found a blue plug towards the underneath, front of the vehicle, but not sure this is it). Any help, including pics or video, would be greatly appreciated. Thanks.
Jon
      Registered and logged-in users don't see this ad!
Register your free account today.
TigerJon73 is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-26-09, 08:11 PM   #2
TigerJon73
Additional question: Can the Pilot's transmission be filled by way of the dipstick spout? Thanks.
Jon
Old 10-27-09, 07:28 PM   #3
Carbuff
Carbuff's Avatar
Usually the drain plugs are a square-hole 3/8" bolt on the lowest point of the trans. You just use the ratchet on it, no socket needed.
You will need aluminum crush washers for the drain and fill holes (if fitted).
If it's never been done before, I would drain and fill the trans fluid TWICE to replace 75% of the fluid. After that, follow a 30K or two-year change interval with a single drain.
Ask where the trans is refilled when you buy the Honda Z1 ATF from the dealer.
Atwell Haines
'99 3.2 TL
'06 CR-V EX, 5 Speed
'07 Fit Sport, 5 Speed
North NJ
Carbuff is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
