| Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX. |
Thread Tools | Display Modes |
#1 | |||||||
98 CR-V front & rear clunking
| Sponsored Links | ||
#2 |
i also have clunking from the front.. the sway bar links looked good but i decided to replace them anyway.... did not change anything because my spring was broken... look for a broken spring... maybe?
#3 |
You can't always hear or feel the links making noise when looking under the car.
From the experience on other forums, replace parts in this order: Sway Bar End Links ... 90% chance of success Sway Bar Bushes ... 5% chance Tie Rod Ends ... 5% chance Last edited by Carbuff; 06-14-09 at 02:41 PM. |
#4 |
thanks for your advice. I have ordered a set of four sway bar links to replace front and rear. Will post results after replacing.
#5 |
Or it may be your shocks!
#6 |
success
I finally got around to replacing the sway bar links and no more clunking. I only replaced the front ones and that seemed to fix everything. Perhaps the clunks that i thought were coming from the rear when the rear wheels went over a bump were actually coming from the front? In any event, I bought all four so I will replace the rear ones anyway. I purchased these as a set of four on ebay for a little over $60.00. Much cheaper than buying at local auto parts store. Also, some advice on replacing; make sure you clean the exposed part of the threads before removing the nuts on the old links. That will make the job much easier. Also, make sure you have a good hex tool for holding the shaft when turning the nut. I had such trouble with one that I had to use my reciprocating saw to cut the shaft since the nut would just not budge after a few turns. Use plenty of WD-40. good luck. larry
#7 | |
Quote:
A Dremel with a cut-off tool can be your best friend on this job. Me, I've encased my swaybar link threads in grease to ward off corrosion. I like to think ahead.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
