Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
Odyssey Sliding door lubrication
Old 07-18-2007, 08:05 AM
Kyle Kraft
Kyle Kraft's Avatar
Default Odyssey Sliding door lubrication
The sliding doors on my '03 Odyssey make the most horrible grinding noises, which seem to be coming from the lower track. I checked for metal shavings or particulates and there aren't any. What lubricant can I use and where do I put it where it won't be a sand magnet?
Old 07-18-2007, 04:35 PM
Fuse
Fuse's Avatar
I use white lithium grease.
Old 07-23-2007, 08:07 AM
Kyle Kraft
Kyle Kraft's Avatar
Doesn't the grease attract dirt? Do you apply it to the wheel at the bottom or on the lower door track?
Old 07-23-2007, 06:05 PM
foot
foot's Avatar
The rollers are a metal shaft with a plastic roller on it. I have replaced a ton of center rollers. You should be able to see every roller in the door with a flashlight. Check to see if you see a shaft without a plastic roller on it.
Old 08-04-2007, 02:57 PM
Kyle Kraft
Kyle Kraft's Avatar
I'll do that!
