Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
Need to disable alarm on Odyssey 2003
Old 12-04-2006, 04:40 PM
sibiryk
sibiryk's Avatar
Default Need to disable alarm on Odyssey 2003
I bought an Odyssey 2003 and the only remote it came with is broken.
I need to disable an alarm temporarily until I will get a new fremote.
Does anybody knows how to disable it?
Old 12-04-2006, 05:59 PM
sleezye
sleezye's Avatar
unlock the door with the key
Old 12-06-2006, 02:43 PM
honda guy
honda guy's Avatar
Basically. Even if the alarm is going off all you have to do is lock than unlock the door with the key (door closed ofcourse)
The following users liked this post:
menscoachhusbanddad (07-04-2022)
Old 12-09-2006, 08:48 AM
sibiryk
sibiryk's Avatar
Ok, thank you guys!
Now I got two remotes. When I use this procedure:
https://www.honda-acura.net/forums/s...ghlight=remote
nothing happens.
Power locks doesn't respond after I complete step 1-2-3 three times.
I tried both remotes.
Should I reset alarm disconnecting the battery?
Old 12-10-2006, 10:25 AM
honda guy
honda guy's Avatar
try it again.
Old 12-11-2006, 11:27 AM
sibiryk
sibiryk's Avatar
Got it!
For some reason I was reading "press Lock and Unlock"
Must be an eyes problem.
Thanks for help!
Old 02-12-2009, 01:17 AM
sparky_00
sparky_00's Avatar
Default 2004 Odyssey Ex-l Alarm going off no reason- HELP
I have a really annoying problem with my 2004 Odyssey. It has been doing this on and off for a couple days now - the alarm just goes off whenever it feels like it. At first it was so rare that it wasn't a major problem, but now it's every time I leave the car! And I'm not even setting the alarm any more - but still it goes off. I changed the battery with a new one, but after 1 day it still is going off and late at night for some reason
If anyone has any ideas about how I can disable the alarm but still be able to lock the car I would be very grateful (as would my neighbors). Thank you
Old 02-12-2009, 11:42 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
I will bet you that the ground wire for your alarm is coming loose.
The same symptoms happened with my last car. It was an aftermarket alarm and the installers used a galvanized self-tapping sheet metal screw that was too small for the hole they drilled. Over time, the screw backed out to the point where the ground lead would cut out.
Since the keyless entry function of most alarms relies on that common ground wire, the best solution is to establish a new ground wire connection that won't rust and won't rattle loose over time.
Use a brass terminal on the end of the ground wire, a stainless steel bolt and nut and an appropriately sized lock washer to make sure neither comes loose.
Old 02-17-2009, 06:51 AM
Jimmy J
Jimmy J's Avatar
My 2000 Odyssey factory alarm has decided to arm itself every time I shut off the vehicle. I find this extremely annoying. It's like HAL from 2001 a Space Odyssey as opposed to a 2000 Honda Odyssey. Please do not tell me to go to a dealer!
Old 07-04-2022, 01:54 PM
menscoachhusbanddad
menscoachhusbanddad's Avatar
I had tried disconnecting the cable under the hood with no success. Then, I saw this one. Boom. It worked and my honking alarm has finally stopped. Such an easy fix! Thank you!
