will front bumper dent simply pull out?
2005 CR-V.....on far left side of front of car it's pushed in from a tangle with a small post in a parking lot.....sounds hollow behind the dented area....can this thing just be pulled out, or somehow pushed out once the cover is opened from inside the wheel well?
Driving a Turbo 2L Terror
if it not to bad u might be able to use a heat gun and gently heat of the bumper and push it from the back, dont leave the heat in one area to long or u will burn thru it. It might or might not work.
