Results 1 to 7 of 7
Thread: '99 CRV Needs New Head?
  1. #1
    Join Date
    May 2005
    Posts
    I was told that my 1999 Honda Cr-V needs its head replaced. It is misfiring on the#2 & #4 cylinders. The check engine light is flashing which makes my car undrivable until it is repaired. Has anyone else had a problem similar to this? The mechanic told me that this was a problem that is known by Honda yet I do not find any information on it. Any input is appreciated.
  2. #2
    I missed Sean sherwood's Avatar
    Join Date
    Aug 2004
    Location
    Fairfield/Bridgeport CT
    Posts
    11,284
    the only problems i know of crv's are the engine fires in the k series crv's
    put a gs-r head on it
    1.8L Acura Integra GSR: Back where it belongs.
    3.2L Pontiac Tran-sport Montana: that things about to go.
    2.2L Honda Accord EX: Sold to my sister
    232CI Mercury Sable: Sold to some lady, by my father, while i was on a camping trip. IMM232
    http://imagegen.last.fm/minimalDark/..._vigilante.gif
  3. #3
    Join Date
    Jul 2004
    Location
    CA
    Posts
    901
    Quote Originally Posted by Alexi75
    yes I've seen a few of the CRV's with 2.0 DOHC motors , the problem is the valves don't get adjusted until 105k or somthing like that so the valves get tight and burn out. if they aren't burn't yet I would check the valve clearance first before replaceing the head if it's burn't then it's too late
  4. #4
    Join Date
    Apr 2003
    Location
    nj
    Posts
    497
    Yeah thats what happens when the valves aren't adjusted every 30k
    Attached Files Attached Files
    Stop asking me for radio codes!
  5. #5
    Honda tech/eprom hackr hondatech's Avatar
    Join Date
    Oct 2002
    Location
    Sacramento, CA.
    Posts
    1,156
    That's not really the problem, the problem is that the valve seats are made too soft from the factory and the valves start to recess into the head. It's a common thing.
    valve adjustment after it starts running bad and mil lights come on do not fix it. You need to replace the head with the updated honda head.
    "Yes sir, your next service will be the
    60k/transmission replacement"
    "Ever wonder why the ppl with the least amount of technical knowledge get to tell the ppl with the most amount of knowledge what to do?"
  6. #6
    Dub L sonicrex's Avatar
    Join Date
    Jun 2002
    Location
    SoCal
    Posts
    170
    Yes, this is a known problem with CRVs. Another frequent issue with the CRVs is with the fuel injectors.
    Add to my vouch thread:
    Vouch Thread
  7. #7
    Registered User foot's Avatar
    Join Date
    Jun 2005
    Posts
    505
    hondatech is right. There is a TSB on the subject. If the valves are tight and you adjust the valves and the problem comes back, the valves are receeding into the head. Replace head.
  8. #7
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
