Minivan, SUV, & Truck RDX, Ridgeline, Element, Pilot, MDX, CRV, Passport, Odyssey, and SLX.
2001 honda passport 4 wheel drive light blinking...
Old 03-09-2005, 04:24 PM
kook-e
kook-e's Avatar
Default 2001 honda passport 4 wheel drive light blinking...
I just purchased a 2001 honda passport and when I try to engage the pushbutton on the 4 wheel drive I get a blinking "4 wheel drive" light on the dash. The previous owner says that this is normal when the car is not on a slippery enough surface to remind you to disengage it. Is this sound right? I don't believe him because the 4 wheel drive does not seem to engage but, of course I do not have a manual to answer this question. Can a guy get some help here?!!!!
Old 12-22-2007, 02:08 PM
99passport
99passport's Avatar
is the vehicle in 4LO or 4HI? check that first, the 4wd disengages at a certain speed . also make sure the vaccum hoses are in good shape and hooked up they are located by the front axle, its a little gear box just off to the passenger side of the axle
Old 02-04-2008, 08:34 AM
jdavies77
jdavies77's Avatar
I'm having this same issue. When the 4 wd drive button is pressed. The light on the dash flashes. You can hear something going on down below, but no matter what speed (shift on the fly) it will not lock in the hubs....
Old 02-04-2008, 07:05 PM
PassportEX
PassportEX's Avatar
sounds either like a bad 4WD module or axle actuator.
Old 03-31-2008, 09:22 AM
rimmies
rimmies's Avatar
Isn't that what it does as it switches into 4wd...that's what mine does...
The following users liked this post:
Nadean (05-27-2021)
Old 05-27-2021, 04:40 PM
Nadean
Nadean's Avatar
No that is a stop driving me flash to get your 100% attention your transmission is failing because you failed to look at everything.
