Results 1 to 5 of 5
Thread: EGR Valve ('01 Oddessey)
  1. #1
    Join Date
    Nov 2004
    Posts
    2
    EGR Valve Replacement ('01 Odessey)
    EGR Valve needs to be replaced. I found the part on line for little or nothing. Anyone know whether this is a DIY job? If so, how is it done?
  2. #2
    Registered User 01usjdmr's Avatar
    Join Date
    Mar 2004
    Location
    FL
    Posts
    148
    there are 2 nuts and 1 plug, if there is a code it must be cleared
    Its odyssey
  3. #3
    Honda tech/eprom hackr hondatech's Avatar
    Join Date
    Oct 2002
    Location
    Sacramento, CA.
    Posts
    1,156
    Why do you think the EGR is bad?
  4. #4
    Senior Member vassil3427's Avatar
    Join Date
    Nov 2003
    Posts
    862
    Most likely if you're getting the insufficient flow code, your EGR port is clogged, not just the valve, Honda recommends you install a stainless steel sleeve into the EGR port after its been cleaned and honed to prevent future clogging-common problem on the odysseys...
  5. #5
    Join Date
    Oct 2002
    Location
    Sacramento, CA.
    Posts
    1,156
    I don't think 01-up is affected by that s/b, I could be wrong but I think I'm not. EGR's are very common failures on newer ody's, symtoms are stumbling at cruise usually. The factory scantool snapshot is nice for verifing this problem but you can unplug the EGR and drive it again to diagnosis the problem. I WOULD NOT put a non factory EGR on a newer honda. It's calibrated to the engine type and you might get a working EGR from the aftermarket but it could cause higher numbers than you want when you smog it.
    "Yes sir, your next service will be the
    60k/transmission replacement"
    "Ever wonder why the ppl with the least amount of technical knowledge get to tell the ppl with the most amount of knowledge what to do?"
  6. #5
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
