ledgend acura 93 starting problem
Old 04-02-2008, 07:36 PM
barber72
barber72's Avatar
Default ledgend acura 93 starting problem
i can start the car up fine but if i go in the store 4 abt 5-10mins and try to start it bck up it wont it, takes abt 25min but .if go in the moves for abt 1hour maybe 2 it starts right up is that a main relay
Old 04-12-2008, 11:30 PM
ari_one
ari_one's Avatar
When it happens turn your radio off and then turn the key only to the acc position and listen. You should hear a quiet groan like sound, that is your fuel pump priming/building pressure. If you don't hear it then there is a good chance it is your main relay.
