Independent Acura/Honda mechanic in PA
Does anyone have an indie in the Pittsburgh, PA area, perhaps even out by or around the Pittsburgh airport? I need to have some work done and I am not anxious to have the Acura dealer do it.
Gary
Gary
What do you need to have performed. honda's are REALLY easy to work on compared to any other imports. any reputable technician should be able to work on it for you. if its an electrical issue or an emissions related issue (check engine light), i highly suggest you go to your dealer atleast for the diag. this will save u lots of headaches and costly repairs. they see the same problems on the same cars all day long, they will know exactly whats up. otherwise feel free to use an independant shop. if you're doing a brake job id suggest either using acura pads or good aftermarket ceramic pads. if its ignition related use oem parts too.
