Ground Noise....just installed an amp.
Old 07-21-2003, 05:08 AM
noyintegra
noyintegra's Avatar
Default Ground Noise....just installed an amp.
Installed an amp over the weekend in the trunk and hook the ground wire to the bolt where the rear strut tower screws. Getting ground noise......is it a bad ground?
Old 07-21-2003, 05:11 AM
90'RS
90'RS's Avatar
Could be I would try a different spot for the ground. I would also make sure that your power and ground aren't ran next to each other.
Old 07-21-2003, 07:45 AM
KMFDM
KMFDM's Avatar
you should be more worried about rca's running next to power wires, not positive running next to ground. you should run rca's on opposite side of car from power.
Old 07-21-2003, 08:10 AM
90'RS
90'RS's Avatar
That's right it's the RCA's that cause this problem. BRAINFART!!!
But maybe this is where the noise is coming from. You also might get a better response in another forum.
Old 07-21-2003, 08:33 AM
Psychosis
Meber
Psychosis's Avatar
besides running rca on one side & power on the other, that ground isn't great; had same problem in last teg.
Old 07-21-2003, 09:26 AM
Spec R
Spec R's Avatar
Find a bolt thats directly threaded into the chassis...and when u find it, sand all the paint and whatever else to expose the bare sheet metal. The ground is the most important wire coming from your amp. You can thousands of dollars in stereo equipment, but it wont mean anything if you dont wire it up right...
I used to get noise also, but it took me forever to find out it wasnt any grounding problems, it was an electronic crossover i was using.
DB Squad
Integra Forum Moderator
