nitrous shot
nitrous shot
when i bougfht my car, the guy gave me a nos nitrous system with it its a 1996 se integra, should i go ahead and put it on and set it to like a 50 shot? or should i sell it? how much hp would it give me? is there a way i can set it so it sprays at like 6500 rpm
I get custom user text?
The only way you can change how much is sprays is by changing the jets. The amount of hp is determined by the size shot ie 50 shot = roughly 50hp. You can purchase a window switch that will engage the nitrous at a set rpm and disable it at another set rpm
I think the your best bet is to set it to the throttle so that when it hits wot it kicks on. If you set it that high on that se your going to blow the motor up. Also before doing this make sure the engine is in good working condition by doing a leak down test. For instructions on how to this check out http://g2ic.com/
