help with tranny fluid bolt??
mexikin who?
which bolt is the tranny fluid filler bolt!! is it the one behind the axle aproxximatly 17mm?? i know wich ones the drain bolt but i cant find the filler bolt!! i have a 1990 integra with a b16a!!:naughty: :naughty: :naughty:
You might want to ask in the Civic Forum. But this might help: http://www.hondaautomotiveparts.com/...ISSION+HOUSING
Manual or Auto? Try your own search. Hope that helps. Good luck, eh.
i think that bolt takes a 1/2 drive....or 3/4", i forget.
mexikin who?
:naughty: :chuckles: :yay: :fawk:
i just finished my task!! it is a 17mm bolt that is right behind the right axle!! it was right in the owners manual:doh: and i put in motor oil for now!! i just gotta get my tags and drive down to a honda dealer and gets some honda MTF
BTW the trannny had not even one quart of liquid in it!! and it got filled with two and a lil bit of the third one!!:thumbup:
thank you all that tried to help!! much appreciation goes to you guys!!
Good Job!!
Just to clarify...
Integra's 3/8" drive (and that's the drain hole, not the fill hole): http://www.c-speedracing.com/howto/t...transfluid.php
Just to clarify...
1/2" I think... True for the Integra.
mexikin who?
Originally posted by mrhonda_187
Good Job!!
Just to clarify...
Good Job!!
Just to clarify...
