Optimal tire sizes for a gs-r
Old 03-20-2003, 03:25 AM
eclipse spanker
eclipse spanker's Avatar
Default Optimal tire sizes for a gs-r
Given the specific characteristics of the b18c1 (and the size of the wheelwell), what do you guys think is the optimal tire size for best straight-line performance ?
Right now I have 195/55/15s, and I was looking at getting some 225/50/15s. I noticed however, that the tires seemed really chunky and heavy, and even though it will improve my launch because of more surface area on the ground, I was thinking that it might bog me down on the take-off alot more, due to the lack of low end torque on the gs-r, combined with the sheer size of the tire. What is your guys opinion...should I go with something a little thinner like a 205, or will a 225 benefit my launch more ?
Old 03-20-2003, 07:22 AM
BonzoAPD
BonzoAPD's Avatar
go with the 205 50's. Closest rotational mass to the stock 195 55's. 225's wouldn't fit on the stock rims. I don't even think 215's would fit on stock rims.
Old 03-20-2003, 08:22 AM
eclipse spanker
Oh yeah; I forgot about the rotational mass. Damn, it seems like everything is a trade off........the wider the tire, the more grip, but more rotational mass and more weight. The thinner the tire, less grip, but less rotational mass and less weight.....
Old 03-20-2003, 08:48 AM
eclipse spanker
Last question for you guys.
For dry weather grip/drag situations.......Parada spec 2s, Kumho MXs, or Falken Azenis ?
Old 03-20-2003, 09:30 AM
ur31337
Colby
ur31337's Avatar
205/50/15 is the way to go.
I'm getting the Kumho MXs on Saturday, they were rated REAL close to the Potenza S-03 on TireRack. $78/each is MUCH better than $117 for an S-03.
Old 03-20-2003, 10:43 AM
eclipse spanker
but are they better than paradas and falkens for a drag setup ?
Old 03-21-2003, 05:11 PM
Tobra
Tobra's Avatar
If you are really going to drag. get some R compound tires and swap them out when you go to the track, and get some bulletproof drive shafts
Old 03-21-2003, 05:44 PM
Weston
Weston's Avatar
I'm pretty happy with my 205/50-15 Azenis. They're very grippy, solid (no flex), responsive, and street legal. They are meant for a 15x6.5" rim, so I wouldn't expect their best results from mounting them on your stock 15x6.0" rims.
They are a bit heavier than normal tires, but their cornering and braking performance more than makes up for it. They're probably not the best choice for drag tires though.
Old 03-21-2003, 06:04 PM
DB7 2.0
Banned
DB7 2.0's Avatar
pshhhh.... 195/50/15 on 0deg front camber and 195/60/15 in the rear
drag racer style. and no its not for looks :squint: its all about gearing baby!
Old 03-21-2003, 06:46 PM
drive4show
drive4show's Avatar
Default GS-R tire size on stock wheels
I'm looking at Yokohama AVS ES100s to replace my worn RE730s. I currently have 205/50-15s; the Tokico performance kit lowered front and back 1.5", so no wheel gap.
I checked out the ES100 dimensional data, found on page 2 of
http://www.yokohamatire.com/pdf/avses100.pdf
205/50R15 has 6.5" Measuring Rim Width, with 5.5-7.5" Approved Rim Width.
225/50R15 has 7.0" Measuring Rim Width, with 6.0-8.0" Approved Rim Width.
So 225s will technically fit on the stock 15x6 wheels.
Any thoughts on going to the 225s, or should I stick with the 205s?
Thanks!
