Thread Tools | Display Modes |
#1 | |||||||
92 LS Starts Then Shuts Off
| Sponsored Links | ||
#2 |
The ELD is built into the fuse box, I've never heard of it going bad before. I would get that checked out first.
#3 |
hmm sounds similar to a crankshaft fluctuation sensor going out, but i dont think ur 92 LS even has one of those.
DB Squad Integra Forum Moderator Integra Build/Journal - Updated 11/02/09 http://www.honda-acura.net/forums/in...read-ever.html |
#4 |
Could it be a timing issue? It tries to start and then backfires and dies.
Edit: Ok I cleared the ECU code 20 but still will not stay started. I cleaned thw IAC and FITV but still no go. I then pulled the spark plugs and the #2 and #4 plugs are wet with gas. I just installed a new coil and ignitor about 2 months ago so I'm pretty sure neither of them are at fault. Dist cap and rotor maybe? Anybody? Last edited by iamnobody; 10-23-09 at 11:26 AM. |
#5 |
Out of curiosity i had to check my chilton's manual for a #20 code. Strangely enough it doesnt show a 20, of course the book also says if it shows a code not on the list, verify it, if you get the same code, replace ecu. Obviously that problem was taken care of. It does say that a 21 is the spool solenoid valve, though i may be no help at all....
| Bookmarks |
| Thread Tools | |
| Display Modes | |
