Go Back   Honda-Acura.net > Auto Forums > Integra & '97-'01 Integra Type-R
Thread Tools Display Modes
Old 09-17-09, 09:05 PM   #1
MonteC
Transmission Guy
MonteC's Avatar
Send a message via AIM to MonteC
Misfire - stumble
92 Acura Integra 5spd. Car has 245k, im hardly ever on here because the car runs great most of the time.
Recently within the last month a misfire or stumble has developed. At first it only occurred at highway speed in 5th gear while cruising. It would just hiccup a little and then be fine.
Now the problem is becoming more prevalent, anything about 3k will stumble but the car is still drivable, i can run 80mph down the interstate it will just jerk every few seconds. If i go above 3/4 throttle the problem will clear up.
At idle i can hear it in the exhaust, and barely feel it in the car, i can rev the engine up to 3-4k and hold it, and it stumbles, but it will rev up without much effort.
I do tune ups every 30k, about once a year, im about 15k shy of a tune up. Been though a few tanks of gas at different stations. I havent had much time to look at the car, im going to try to look at it Saturday. But wanted to gather opinions before i tear into it.
I need to replace the fuel filter, do a fuel pressure check, check the distributor. Check the injectors. Btw NO CELL LIGHT. The light works properly but the car is not throwing any codes.
      Registered and logged-in users don't see this ad!
Register your free account today.
Daily: '92 Acura Integra /248k on stock drive train/
Current Project: '84 Camaro Z28 Ls1/T56 Swap
Distant Project: '86 Monte Carlo SS LSX Swap
MonteC is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-19-09, 07:14 AM   #2
AcuraLsSE
ASE Certified
AcuraLsSE's Avatar
I would check: spark plugs, wires, distributor, fuel filter, and injectors. Start with the easier stuff first. I don't know if the OBD 1 reads misfires but I know that my OBD 2 will throw a code when it had a misfire.
1996 Integra Special Edition 5 speed
Fidanza short shifter, Stage one Exedy clutch w/10lb Exedy flywheel
350f 400r Ground Control coilovers with koni yellow shocks
Skunk2 camber kits front and back type r sway bar w/ASR sub frame brace
Oversized JDM type r pistons
AcuraLsSE is offline   Reply With Quote
Old 09-19-09, 10:24 AM   #3
Lynxs1981
They're bad about randomly eating plug wires.
My fully tuned 99 GS-R, 250+ HP
Short clip of it here
Lynxs1981 is offline   Reply With Quote
Old 09-19-09, 04:47 PM   #4
cruzalekz
check rotor in the distributor.
also possible that your ignition coil is about to go
cruzalekz is offline   Reply With Quote
Old 09-21-09, 05:57 AM   #5
MonteC
Transmission Guy
MonteC's Avatar
No time on saturday. Didnt feel like driving to the shop to dick with it on sunday. Might have a few hours today. But it is getting worse.
Old 09-21-09, 05:08 PM   #6
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
Send a message via AIM to JoePoonani
Have you replaced the dizzy cap and rotor? Also the coil may be weak.
09 Civic EX - current DD
03 VW Jetta Wolfsburg Edition 1.8T APR tuned - totalled
94 Integra LS - sold
94 Civic Ferio - stolen/raped
JoePoonani is offline   Reply With Quote
Old 09-21-09, 07:16 PM   #7
MonteC
Transmission Guy
MonteC's Avatar
hold down bolt for the rotor backed out. Luckily it didnt move too far or the car would have quit running. It moved just enough to jump time a smidge. Replaced the torn up cap and rotor and the car is back to normal.
Funny thing is this is the second time the bolt has backed out. Last time my wife got stuck on the side of the road. this time I found a new bolt and used a dap of locktite.
300k here i come!
Old 09-22-09, 09:39 AM   #8
Lynxs1981
Nice, easy fix. Locktite is always a good idea on those bolts, just don't over do it. You might want to get it back out later.
Old 11-01-09, 06:18 PM   #9
joe_kewl81
joe_kewl81's Avatar
Send a message via Yahoo to joe_kewl81
check the air intake for cracks, and any obvious old vac lines.
joe_kewl81 is offline   Reply With Quote
Old 11-02-09, 01:10 PM   #10
MonteC
Transmission Guy
MonteC's Avatar
Quote:
Cars been running fine for a few months now. thanks.
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
