Results 1 to 4 of 4
Thread: What Next? to Fix Dipping/Low Idle on GSR
  1. #1
    what else needs to be replaced to cure dipping/LOW idle on '94 Acura Integra GS-R?
    My Symptoms: 1500rpm idle after cold startup & 700-750rpm idle after warmup but, the idle/tachometer consistently drops down to 500-600rpms when coming to a stop or when coming out of gear and feels as though the engine is going to die/cut out with an erratic idle feel then will climb back up to the normal 700-750rpm idle.
    what else needs to be fixed/replaced? i have listed all the parts i have fixed/swapped out so far and read every TI archive here so i would greatly appreciate any help or information especially from those that have suffered the same or if there are any honda/acura mechanics here that can help me or point me in the right direction...please! thank you.
    130,000 (current miles on my '94 Acura Integra GS-R)
    Checked Distributor Cap/Rotor and Cleaned/Sanded Contact Points
    Checked ALL fuses to see if blown in Engine bay and Underdash fuse boxes
    Checked ECU for any trouble codes but NONE displayed
    Checked Ground Wires and seem to be in good/solid connections
    Cleaned out Throttle Body Butterfly during IACV install and cleaned/re-oiled K&N cone filter.
    131,368 BLOX Throttle Postion Sensor
    127,072 Rebuilt OEM Starter @ Rite-way Electric
    127,061 FITV
    119,796 PCV Valve
    115,000 IACV (don't clean, just replace trust me on this!)
    114,441 Rebuilt OEM Nippondenso Alternator @ Rite-Way Electric
    114,440 Fuel Filter
    104,691 Kirkland Battery - 12.8 volts with no load & 14.4 volts while idling
    95,373 Main Relay
    87,617 Distributor Cap/Rotor
    86,842 Thermostat
    73,451 Ignitor and Coil
    64,040 PCV Valve
    56,961 MSD Spark Plug Wires 8.5MM
    *Switched back to OEM Acura Ignition Wires (w/ 56K previsously)
    51,356 Denso Platnium Spark Plugs
  2. #2
    F#%K JDM, USDM FTW pslsnakes's Avatar
    Join Date
    Apr 2008
    Location
    Garage kept in Florida
    Posts
    539
    Has this always happened, or did it just start happening out of no where?
    E85 Powered
    '00 Civic B18B-T
    Daily - 237whp @ 8lbs (12.8 @ 106)
    Track - 381whp @ 18lbs (11.8 @ 117)
  3. #3
    The idle problems started about 115,000 miles. I'm at 130,000 miles right now.
  4. #4
    Join Date
    Aug 2005
    Posts
    642
    do valve adjustment. make sure the exhaust valve is at the max side of the spec they provide on your underhood label. the intake valve right in the middle of the spec..
    clean throttle body and also im curious about the signal voltage of the blox tps at idle. if its adjustable, cant really set it too low otherwise car might die on you or throw a code if it fall off the parameters.
  5. #4
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
