Front Brakes Dragging Need Help
Bored Enthusiast
I have a 97 Acura Integra LS with 117,000 Miles on it.
The front brakes have been dragging so I replaced all the brakes on the car with ceramic brakes and got the rotors machined. The front brakes are still dragging even though the seals in the calipers are not broken. (however the rear brakes aren't dragging at all) I also re-greased the caliper slides.
The hydraulic brake fluid has never been flushed so I am going to do that, but I am thinking it is probably that the brake master cylinder is going bad.
Any suggestions?
Thanks
Any suggestions?
Thanks
Any suggestions?
Thanks
Any suggestions?
Thanks
DB Squad
Integra Forum Moderator
DB Squad
yep this is true also, it happens when douche techs let the calipers dangle by the brakelines when they change out pads. it makes the brake lines basically one way check valves
DB Squad
DB Squad
