Rotor Screws
Old 07-27-2008, 03:05 PM
TheBlazer
TheBlazer's Avatar
Default Rotor Screws
Hey guys,
I understand that there are already a few threads regarding this topic, but none of them answered my question. Rather reviving a 2 year old topic, I figured it would be best to start a new thread...
I am replacing the front rotors on my 94 GSR, and it appears that the two philip head screws are seized. I understand that a pneumatic impact driver is best to remove these, but I do not own a compressor. Rather than trying to un-torque these with a regular scredriver (and most likley stripping or breaking them), I am wondering if a 'Yankee Screwdriver' (push-style) would do the trick:
http://www.duckworksmagazine.com/06/...ewdriver-s.jpg
Thoughts? Is this just a bad idea from the get-go?
Cheers!
Trizoy
Old 07-27-2008, 03:42 PM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
You will not be able to generate enough torque with that type of screwdriver. There must be some auto parts store near you who will rent you a driver and compressor for the half-day it will take to swap the rotors.
It's really one of those situations where the trouble and strife of trying to engineer a solution isn't worth the expense of renting the proper tool.
Old 07-28-2008, 12:19 AM
TheBlazer
TheBlazer's Avatar
Thanks, TheOtherDave.
That is an option that hadn't even crossed my mind, and one that sounds better overall.
Cheers!
Trizoy
Old 07-28-2008, 04:29 AM
Lynxs1981
Lynxs1981's Avatar
I just used a large phillips driver and a hammer.
Old 07-28-2008, 06:03 PM
Spec R
Spec R's Avatar
drill them out with a hardened bit.
DB Squad
Integra Forum Moderator
Old 07-28-2008, 06:57 PM
AcuraLsSE
ASE Certified
AcuraLsSE's Avatar
Thats what I ended up doing on my friends car. Although hers were already stripped.
Old 07-29-2008, 08:48 AM
JoePoonani
Lexus Tech y0!!
JoePoonani's Avatar
Drill the heads off and the rotor comes right off. No need to replace the screws.
Old 08-01-2008, 06:42 AM
kingiiii
kingiiii's Avatar
I need to do the brakes on my 99 LS for the first time. When i take out the screws that hold the rotor on, I don't need to replace them? What are they there for?
Old 08-01-2008, 06:54 PM
Spec R
Spec R's Avatar
replacing them is up to you, they're there mainly for assembly purposes at the factory when they build your car.
DB Squad
Old 08-01-2008, 08:21 PM
2001TEGGSR
2001TEGGSR's Avatar
Just to correct some information here, this type of impact driver works just fine. An air compressor is not required.
