suspension questions...
Old 06-13-2008, 02:22 PM
tonamal
tonamal's Avatar
Default suspension questions...
i have a 95 integra ls in which i put type r shocks fron t and rear with type r control arms...as for springs i have tein s tech...i have a skunks 2 pro camber kit on the front and rear...i was thinking about upgrading to different shocks....what are some good choices.....i dont think im looking to do coilovers....tokico...bilstein...what do you guys recomend? i have read through some tech articles and im clueless as far as spring rate and all that goes.
Old 06-13-2008, 05:31 PM
jesusublime99
jesusublime99's Avatar
Its not easy to recommend a set of dampers without knowing your spring rate, but off the top of my head I would say KYB GR2 or Koni reds. Seems like you don't need adjustabilty. Stay away from Tokico blues.
Call Tein and ask them which ones they recommend for your car with their springs.
Old 06-13-2008, 08:46 PM
2001TEGGSR
2001TEGGSR's Avatar
I will always recomend Koni yellows. They carry a lifetime warranty, offer some height adjustment without using coilovers, and are easily adaptable to changes in spring rate. You can also adjust with comfort in mind.
Koni's are definitely the best bang for your buck, performance is on par with full coilovers priced at 3 times there MSRP.
Your S tech springs will work just fine, but why are you against a coilover?
Old 06-14-2008, 08:54 AM
tonamal
tonamal's Avatar
i just dont have the money for coilovers...also i cant use kyb gr2 cause they dont work for type r....what about bilsteins? i know u cant be cheap and get a great product but im not looking to drop $1000...
Old 06-14-2008, 04:09 PM
2001TEGGSR
2001TEGGSR's Avatar
I paid $450 shipped for my koni yellows on Honda-marketplace.com
If your happy with your S tech springs, pair them up with the Konis for now. If you ever want to upgrade to coilovers or a stiffer spring, the shocks are adjustable and will accept either.
Last I checked bilsteins were a bit higher in cost, and offered no adjustability. I have them on my truck, they are a well made product but I still think konis are better for the integra.
Old 06-15-2008, 04:27 PM
tonamal
tonamal's Avatar
what about these shocks.....Tokico HTS Series Adjustable Gas Shock Absorber.....i found them for about 600 and they seem to be extremely adjustable....
Old 06-15-2008, 05:48 PM
2001TEGGSR
2001TEGGSR's Avatar
If your willing to spend that amount, stay away from Tokico at all cost.
Many, many people will agree with the suggestions I've given you....
Old 06-15-2008, 06:42 PM
tonamal
tonamal's Avatar
what should i do first....price is pretty close for either...
koni yellows.....$550
or
ASR subframe brace with 24mm sway bar full kit...$450
Old 06-15-2008, 10:43 PM
jesusublime99
Listen to 2001TEGGSR, he's getting tired of repeating himself and he's absolutely right.
Koni yellows before any suspension mod.
Old 06-16-2008, 08:25 AM
bnuk
bnuk's Avatar
word.
