CAr WOnt Start NEED HELP ??????
was drin=ving in my 91 integ yesterday and the rpm jus started lowering i down shifted the same till i pulled over cuz it died tried to start nothing starter was loose tightened it then dropped ratchet on power it sparked and i grabbed the ratchet then i put the key no signal no nothin i went to pick up the car today i got signals but the lights are dimm no power and the seatbelt computer is buzzing need help asap
tryed jumping the car nothin then my cousin by mistake or on purpose idk hit the wires together i guess shorting back the battery and it got power everything worked i tryed to start it crank but wouldnt run i think it might be fuel because when it dyed when i was driving it was like i was down shifting where is the pgm fi relay located if notthat maybe fuel pump need location of that relay ......
The Duke of Earl
U cud have fused some of the cells in ur battey when u arced it. Jumping a destroyed battery wont give u enough power. Try to borrow a battery for a second. Its probably ur problem. Jumper cables dont do as much as u think
stopped being lazy got up in this hot weather and checked out my teg turned key fuel pump primes i can hear it the took off plug wire put plug in it and as i suspected but hoping not there was no spark goin to pick up a ditributor this weekend and do my plugs and wires they are old
