Fuse Keeps Blowing Need HElp
Old 04-24-2008, 08:37 AM
youngtex06
youngtex06's Avatar
Default Fuse Keeps Blowing Need HElp
the gauge cluster and running brake lights fuse keeps blowing as soon as i put it in and turn on the lights any ideas or answers to wat it might be need help asap or i cant drive at night
Old 04-24-2008, 08:47 AM
jinx-mitchell
The Comic Guy
jinx-mitchell's Avatar
I don't know these cars very well but it sounds like a short. Follow the affected wires and look for any short, and if the wires are really tight around any metal brackets or other metal pieces, that is probably where you short is.
Old 04-24-2008, 11:42 AM
TheOtherDave™
Apathy Kills
TheOtherDave™'s Avatar
It's most likely a short.
If you've got a multi tester and some 8 gauge wire, check for continuity between the terminal in the fuse that keeps blowing and the leads on that circuit.
If you don't have the money for a HELMS factory shop manual, get a cheap Haynes manual from your local Kragen/Auto Zone / etc. You'll need it.
Old 04-24-2008, 12:41 PM
2001TEGGSR
2001TEGGSR's Avatar
You can get a PDF version of the helms from: http://www.hondahookup.com/manuals/
(Registration required)
