usdm type-r
slow and low
usdm type-r
i am interested in buying a 5-lug type-r disc brake conversion. i am unsure of the axle splines on the usdm verses the jdm setups. and can i also use regular teg/civic rear lower control arms on a usdm r rear disc? any help would be much appreciated.
I think the JDM axles are larger than the USDM models. If they don't fit, you only need the outer joint, as it will mate to your current axles.
Regular LCA's will bolt up.
