Rear Trailing Arm Question
Old 04-17-2008, 09:46 AM
Schwa
Schiggity
Schwa's Avatar
Default Rear Trailing Arm Question
Would it be easier to replace the whole RTA assembly, rather than keep what I have and press out the bushing?
I'm asking because I have an opportunity to grab some RTA's from a guy parting his car and wondering if this is easier.
Let me know if this is a retarded idea. I'm not 100% clear about geometry back there so I coudl be way off base
Thanks!
Old 04-17-2008, 10:23 AM
whatinthe
The Duke of Earl
whatinthe's Avatar
I bought the bushings and replaced them. I dont think it a major load point though because the rubber is very soft and theres not alot of it. I think it was like 40 to get them pressed and a day or so of no car. It did tighten up the rear end though. If u have the money go for new.
Old 04-17-2008, 11:25 AM
2001TEGGSR
2001TEGGSR's Avatar
You need a tool to clock the bushing properly, the task shouldn't take longer than a few hours.
Old 04-17-2008, 04:03 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Like a grease pencil? h:
I beat mine out while they were still on the car with a hammer and beat the new ones in. Took about 20 minutes per side. Replacing the entire RTA is a total PITA, so I suggest you avoid that route if you can.
Old 04-18-2008, 07:29 AM
2001TEGGSR
2001TEGGSR's Avatar
Sorry my post lacked info...
Grease pencil to mark its position, and this tool to take the bushing out.
Amazon: Trailing Arm Bushing Xtractor
But it is a bit pricey so beating them out with a hammer is probably the best option. Here is a decent write up too if you need it. http://www.honda-tech.com/zerothread/1456600
Old 04-18-2008, 07:58 AM
bnuk
bnuk's Avatar
*results may vary....
When I did my bushings a couple years ago it was a real battle. I think it depends on how much exposure your car has had to the elements/salt. But there was no way mine were going going to come out with a hammer. It took all 20 tons of a 20 ton press to get them out.
There is another method where you cut/burn all the rubber out and then slice the metal sleeve with a hacksaw and then you can just peel it out.
Old 04-18-2008, 09:57 AM
Schwa
Schiggity
Schwa's Avatar
Okay guess I will do only the bushings.
I want to avoid buying the tool if possible, so I guess I will try the BFH method.
Can someone elaborate on "clocking" the bushing. Not sure I understand this part
Old 04-18-2008, 10:09 AM
Provocateur
On permanent hiatus
Mark how the middle piece is positioned and reinstall the new one at the same angle. You'll understand when you look at it.
Old 04-18-2008, 10:57 AM
whatinthe
The Duke of Earl
whatinthe's Avatar
Take them to a machine shop. $20-$30 bucks and the new ones will have a "this side up" mark
Old 04-18-2008, 05:57 PM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
100% will come out easy with a hammer but about 90% will be a PITA to get in.
