pulley's plus system = bad combo?
i was looking into getting some AEM pulleys for my 97 teg. I was told that it might not be a good idea for me to get the pulleys because I have a system in my car. I use a 425 watt MTX amp that pushes two lil bitty 8's. What do you think?
Knowledge Speaks, Wisdom Listens.
The alternator will run slower... if you drive hard, you should be ok (higher rpms)... if not, you may find your battery gets drained quite often when you've been cranking the system.
you'll be fine. when you stop, your headlights might dim a bit whenever it hits, but when you drive, and you dont have to drive hard, it wont matter that you have pulleys. so pretty much, whenever your not at idle, everything will seem the same.
gangters don't dance, we boogie.
I'd stay away from pulleys as a general rule. Read this white paper by Steve Dinan (the famous BMW tuner). He knows a lot more about this subject than practically everyone.
http://www.dinanbmw.com/html/danger_...er_pulleys.htm
he is talking about the harmonic damper. not the accesory pulleys. you car couldn't care less if you ran no accesory pullies. but if your remove the harmonic damper, your engine will vibrate itself to death.
If you want to get the pulleys go ahead, I wouldn't, because you should be able to get a capacitor and solve that problem of the headlights dimming. The capacitor should store enough power so that when you are stop at lights and so on your lights won't dim
H&R OE Springs
KYB GR-2 Shocks
Short Ram Intake
Right, but I was simply alluding to the fact that, at least in BMWs, the harmonic damper is built into the accessory drive pulleys. Many aftermarket pulleys do not include the damper and that is what can cause problems. Maybe it's not the same for tegs, but anyone considering this mod should certainly look into it and make sure. Reading this paper doesn't hurt. If you don't understand how an aftermarket part works and why it was designed a particular way, you might want to stay away from it.
Also, modern cars need electricity to run for any length of time (ECU, fuel pump, HVAC, radio). Removing your accessory pulleys, as you stated, would not be the smartest thing to do. You could probably drive for a little bit until the battery dies, but then you'd be stuck.
i doubt that the aem gears slow down the alternator enough to drain the battery. Im almost certain there isn't a harmonic damper in the alternator or power steering pulley. I know there is on on the crank but this would not be removed. The alternator isn't totally shut off just slowed down a bit. I doubt you even have to drive hard to get enough voltage for you system. Do know if your amps or regulated or not? how loud do you usally listen to your music?
RIP Karina Lau. Causualty of the conflict in Iraq and my friend
Audio: Arc/stinger/crossfire/ed/cdt/eclipse. Comptech ice box, spoon strut bar, type r clutch, act prolight flywheel.
on hondas, the harmonic damper is on the crank. i know this because i helped my friend install and underdrive pully on his alternator. we removed the power steering belt. after we put in his system(1000 watts total power) his lights dimmed slightly when it hit hard. but we put in a 1 farad cap and its fine now. and hondas, as do pretty much every other car, have a voltage ragulator in line with the alternator. if they didn't, everytime you got the engine above idle you would fry the electrical system in your car because it would push waaaay more than 14 volts.
if you still have anymore questions, dont be afraid to ask!
So OG it hurts.
I have the power steering pulley for an integra. I'm tryin' to get rid of it cheap. It's a red AEM pulley, just the power steering. If anyone wants it, E-mail, or PM me.
Ok heres is what scc had to say on the topic
There is some controversy about the pulleys, as they are not equipped with the harmonic balancer that the stock pulley has. We feel the risk of removing the balancer on certain engines is not really a risk. Inline, four-cylinder engines for the most part have short, stiff crankshafts. These do not need a balancer as much, because of their high natural frequency. Engines with long, whip-like cranks, like inline six-cylinders, need balancers to prevent failure, but most four cylinders do fine without them.
http://www.sportcompactcarweb.com/pr...scc_proj200sx/
... You don't hafta click that to see that has nothing to do with an Acura or a Honda.
Just because they're talking about an inline four doesn't mean they're talking about our inline fours.
"a ray of sunshine is even more beautiful in the midst of REIGN."
Honda-Acura
Honda S2000
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Search Engine Friendly URLs by
vBSEO 3.5.2
Bookmarks
