Identify this clutch noise (.wav attached for listening pleasure)
1996 Integra LS
127,xxx miles
Original clutch
When I press the clutch pedal down in neutral, it makes this noise, which continues until I release the pedal or move the shift knob to a gear:
http://www.mediafire.com/?49eddgvxhpe
Shifting is becoming a bit resistant.
There is a small amount of clutch fluid leaking around the connecting rod behind the clutch pedal. I recently had to top off (about 1/2 ounce) the small clutch fluid reservoir.
My question would be whether this sounds like a clutch failing completely, or related to the slave/master cylinders, which obviously need replacing?
Thanks all,
127,xxx miles
Original clutch
Thanks all,
Trow out bearing or maybe the pressure plate?If you have a hydro leak it can make for a hard shift because the clutch will not release all the way. But a hydro leak will normally not come with a noise just fucked up synchronizers long term.
On permanent hiatus
Keeping an eye on that. Fluid levels have stayed steady, and the amount of residue around the CMC clutch pedal shaft hasn't increased. Would probably replace both CMC and CSC at the same time.
