Results 1 to 4 of 4
Thread: A/c Belt????Help
  1. #1
    Join Date
    Mar 2008
    Posts
    A/c Belt????Help
    Any help would be great, I have trying to get this a/c belt off forever. I can get the P/S belt and Alt. belt and I can get the a/c belt off the pulleys but I can't figure how to get the a/c belt off with the a/c braket in place, Do I have to remove the braket?
    thanks
  2. #2
    ************* jesusublime99's Avatar
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    449
    Support the engine with a jack and maybe a piece of wood on the timing belt side.
    Unbolt the lower motor mount from the frame.
    Lower the engine with the jack just enough to remove the AC belt and put the new one in.
    Raise the engine again and put the motor mount bolts back in.
    '00 Integra LS
    '95 GSR... finally
    My GSR build - 152 tq, 196 hp
    www.DPRracing.com
  3. #3
    On permanent hiatus
    Join Date
    Jul 2004
    Location
    A forum with actual tech
    Posts
    9,716
    Quote Originally Posted by jesusublime99 View Post
    You really need to remove that front torque mount entirely. That mount isn't essential (I'm not running one since there are clearance issues) and shouldn't cause the engine to move at all when removed. Just remove all 3 bolts and it should come out without issue.
  4. #4
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    449
    Quote Originally Posted by Provocateur View Post
    You're right, you wouldn't need a jack just for this belt.
    Now that I remember, my engine was on a jack because the top mount was unbolted while I was doing my timing belt.
    '00 Integra LS
    '95 GSR... finally
    www.DPRracing.com
  5. #4
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Friendly URLs by vBSEO 3.5.2
